![]() | Home > General > Engine Failed |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Define: ruined. What exactly happened? Regards etc.,
jamesholland111 Member Since: 14 Mar 2016 Location: London Posts: 5 ![]() ![]() |
Thanks for coming back to me. According to my garage uneconomical to start investigating further without completely stripping the whole engine down part by part. The compression ratio on the right hand side of engine is low, but this is more than likely due to ingesting part/s of the turbo. |
There's no (economical) point in fixing it if the turbo made its way into the cylinders. I have absolutely no idea if the company I link has any good or bad reviews, but try http://rangeroverreconditionedengines.co.uk/ for a quote. Better yet, search for a possible writeoff with same engine and swap it - if it still does make sense in terms of money. As I see in Poland, a TDV8 goes for about 3300 pounds + fitting.
Thats what i was worried about. I have a very well known and reputed LR RRS specialist and he says you hear stories of this every day. He is reccomending a new LR approved engine, if not he offers no guarentee when you come off the forecourt otherwise he ends up getting sued for someone elses bad engine. I wonder what a 2009 V8 non runner would get at auction. |
This could work but again you get very little guarentee on the engine and on a 2009 how long does it take until the electronics fail and you have paid double for a car? |
Thanks, that's an information worth to know.
Most probably zero guarantee (though I've seen RHD cars used as donors still being available to test drive before the engines were lifted from them). Regarding the rest... it's a Land Rover. It will fail, eventually. Be it my RRC I used to have or the P38 (I believe the current owner still wants to bring the car back to its glory, poor fella). This said, I still think they are quite good for the age. I used to have a Lancia once, you know... Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
Who is looking at the car? Is it a LR dealer, a LR indie or just a "garage"? If it's just a normal garage it might be worth talking to someone like Rovertune in Reading. Getting it trailered to them to be worked on wouldn't be too much compared to the cost of the work being done.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4440 ![]() ![]() ![]() |
I have replaced a few set of turbos now, whereby the turbos have blown, and the engine has ran very, very rough
Its a land rover chap used to work at a dealership and set up. Trusted and known by a few people i know. |
Michael7s Member Since: 26 Oct 2014 Location: London Posts: 38 ![]() ![]() ![]() |
dealers do not sell any engine components at all, so you any ordinary garage won't be able to fix it, even if they repair engines.
Land Rover won't sell engine bits to anyone so you can't recon a TDV8; you could get hold of a couple of units from a scrappy and use the best bits from each to make one "maybe good" engine. Better to get an engine from LR though. At least you'd get two years of warranty. Eye wateringly expensive though.
9k for an engine plus fitting for a car worth 10??
If it was me (and let's face it - one day it could be) perhaps I'd have it transported up to Disco_Mikey to look at given that he appears to have rescued a few declared lost causes by other establishments.
