Home > General (L494) > Extended height mode |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 |
thread resurrection
Thu Feb 28 2019 11:46am |
had no one tried this? --
Sat Mar 02 2019 10:42am |
finally got some feedback, Pat was very helpful:
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Tue Mar 05 2019 7:28am |
GregP Member Since: 21 Jul 2017 Location: Gosford Posts: 52 |
I installed LLAMS on mine. It works a treat. It can lower or raise from whatever your car height setting is. 1 lower setting and 2 higher settings (plus an off setting) . I installed the adjustment knob on the small section of dash to the right of the steering wheel. see http://www.llams.com.au/ MY15.5 SDV6 HSE Dynamic without the H . Yulong White |
Tue Mar 05 2019 9:42pm |
Thanks Greg.
Tue May 07 2019 6:34am |
Interesting, because when I use the IID tool, the maximum increase is +25mm when front & rear are linked.
Tue May 07 2019 7:07am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 |
Bear in mind that the system has a finite range of movement. It might be that with your vehicle in off road height 2 plus the 25mm the IID added, you were at the physical limit of travel of the suspension. Remember that the front suspension has slightly less total travel available than the rear.
Tue May 07 2019 3:40pm |
Yeah, I know.
Tue May 07 2019 4:08pm |
Sorry, reading that back it does come across as a bit "teaching granny to suck eggs". 2012 SDV6 - it's missing a couple of cylinders
Tue May 07 2019 5:41pm |
nah, it is always useful be to reminded of the basics --
Wed May 08 2019 2:54pm |
