Home > General (L494) > Extended height mode
thread resurrection
has anyone used their IID/LLAMS to lift their L494 when off-road, and if so, what was the max you used?
thanks --
Post #576060 Thu Feb 28 2019 11:46am
had no one tried this? Shocked --
Post #576181 Sat Mar 02 2019 10:42am
finally got some feedback, Pat was very helpful:
Quote:
For temporary usage, raise it to the maximum...
Its preferable to raise both front and rear equally.
Post #576414 Tue Mar 05 2019 7:28am
GregP
Australia
I installed LLAMS on mine. It works a treat. It can lower or raise from whatever your car height setting is. 1 lower setting and 2 higher settings (plus an off setting) . I installed the adjustment knob on the small section of dash to the right of the steering wheel. see http://www.llams.com.au/ MY15.5 SDV6 HSE Dynamic without the H . Yulong White
Post #576478 Tue Mar 05 2019 9:42pm
Thanks Greg.
Out of curiosity, what's the maximum extra height that the Llams allows you to set?
I'm asking because this weekend we went off-roading, and I set the car to +20mm via the IID tool, and still could not complete the course. Even when I was beached, I couldn't get extended mode.
For example:
Post #580399 Tue May 07 2019 6:34am
GregP
Australia
The Medium setting will add 30mm to whatever height you have the car at.
If you use the High setting while in Off-road setting, you apparently get the equivalent of super-extended mode. I have not tried this.... Shocked MY15.5 SDV6 HSE Dynamic without the H . Yulong White
Post #580403 Tue May 07 2019 6:57am
Interesting, because when I use the IID tool, the maximum increase is +25mm when front & rear are linked.
After +25mm, only the rear can go up more, but that would make the vehicle not level and GAP do not recommend this.
I wonder how it is that Llams can do +30mm and also access super-extended mode... --
Post #580405 Tue May 07 2019 7:07am
Bear in mind that the system has a finite range of movement. It might be that with your vehicle in off road height 2 plus the 25mm the IID added, you were at the physical limit of travel of the suspension. Remember that the front suspension has slightly less total travel available than the rear.
The Disco 5 has slightly more ground clearance (just as the D3 had slightly more than the RRS1) which may be why he was able to get through where you weren't.
Ultimately, we're all limited by ground clearance issues. That's why the Defender boys fit body lifts - it gives better clearance under the cills etc but also, crucially, allows larger diameter tyres which give overall clearance improvements such as below the diffs. 2012 SDV6 - it's missing a couple of cylinders
Post #580438 Tue May 07 2019 3:40pm
Yeah, I know.
I'm looking at swapping my 255/55 road tyres for 275/55 or 275/60 AT ones, should also help a bit --
Post #580443 Tue May 07 2019 4:08pm
Sorry, reading that back it does come across as a bit "teaching granny to suck eggs". Embarassed Embarassed 2012 SDV6 - it's missing a couple of cylinders
Post #580446 Tue May 07 2019 5:41pm
nah, it is always useful be to reminded of the basics Thumbs Up --
Post #580520 Wed May 08 2019 2:54pm
