![]() | Home > General (L494) > Extended height mode |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1177 ![]() ![]() ![]() |
thread resurrection
had no one tried this? |
finally got some feedback, Pat was very helpful:
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
GregP Member Since: 21 Jul 2017 Location: Gosford Posts: 52 ![]() ![]() |
I installed LLAMS on mine. It works a treat. It can lower or raise from whatever your car height setting is. 1 lower setting and 2 higher settings (plus an off setting) . I installed the adjustment knob on the small section of dash to the right of the steering wheel. see http://www.llams.com.au/ MY15.5 SDV6 HSE Dynamic without the H . Yulong White |
Thanks Greg.
Interesting, because when I use the IID tool, the maximum increase is +25mm when front & rear are linked.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9021 ![]() ![]() ![]() |
Bear in mind that the system has a finite range of movement. It might be that with your vehicle in off road height 2 plus the 25mm the IID added, you were at the physical limit of travel of the suspension. Remember that the front suspension has slightly less total travel available than the rear.
Yeah, I know.
Sorry, reading that back it does come across as a bit "teaching granny to suck eggs". |
nah, it is always useful be to reminded of the basics |
