needle
Active Stabilization Pressure Control Valve Error code | |
Help please ,Got a the red warning on my 2005 SC , Ran the IID tool and its came back with C1B11-62 (2e) error code which is as below , I noticed the fluid level was low so topped it up and it seemed ok for 5 miles ish but back on .
Is it possible to check the pump pressure with IDD Tool and what should it be? Is it more likely the pump ?
I also noticed that the suspension ( all corners ) would drop after a day or so just a few days prior to this fault ?
Is it possible to bleed the system with IDD Tool or will it need Stealer ?
Any advice on what to check first appreciated ,cheers
Low/Contaminated fluid
PCV fault
Low flow/low pressure pump Pressure
transducer fault
Air in system
Check fluid level and condition. For sticking/faulty valves,
install a new valve block.
Valve Block (60.60.20) Check the pump operation and
hoses, rectify as necessary. Install a new pressure
transducer as necessary.
Valve Block Transducer (60.60.22) Carry out the manual
bleed procedure.
Active Stabilization System Bleeding (60.60.13)
Mon Feb 08 2016 8:17pm |
