Home > Technical > Active Stabilization Pressure Control Valve Error code
needle
Help please ,Got a the red warning on my 2005 SC , Ran the IID tool and its came back with C1B11-62 (2e) error code which is as below , I noticed the fluid level was low so topped it up and it seemed ok for 5 miles ish but back on .
Is it possible to check the pump pressure with IDD Tool and what should it be? Is it more likely the pump ?
I also noticed that the suspension ( all corners ) would drop after a day or so just a few days prior to this fault ?
Is it possible to bleed the system with IDD Tool or will it need Stealer ?
Any advice on what to check first appreciated ,cheers
Low/Contaminated fluid
PCV fault
Low flow/low pressure pump Pressure
transducer fault
Air in system
Check fluid level and condition. For sticking/faulty valves,
install a new valve block.
Valve Block (60.60.20) Check the pump operation and
hoses, rectify as necessary. Install a new pressure
transducer as necessary.
Valve Block Transducer (60.60.22) Carry out the manual
bleed procedure.
Active Stabilization System Bleeding (60.60.13)
Mon Feb 08 2016 8:17pm
Socast
I recently replaced the valve block on mine, my fault turned out to be the pump.
So long story short, I've got a guaranteed working good condition valve block. It's listed on fleabay but feel free to make me an offer.
The system should self bleed (to a degree), the ACE pump is just below the reservoir on the left of the vehicle (as you look at the front). I've got a .pdf with everything you could ever need to know about the system, drop me a pm if you would like it.
Have a listen to the pump, mine is currently whining at around 1200rpm. I'm not getting any dash lights though, my system works as it should, it's just noisy.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
