Home > Wheels & Tyres > Quick wheel alignment check with measuring tape
jochem00
I just did a quick wheel alignment check on the front wheels with the help of a measuring tape.
first measured the distance between centre treads on the front side of the front tires underneath the car and then the distance between the same treads on the rear side of the tires.
I got a difference of +2mm on the front side so the wheels are toeing out.
Can someone confirm if this is OK and similar to a car where the wheels have just been aligned?
Post #482524 Tue Dec 15 2015 7:21pm
Tyrefitter
Its not just the fronts you need aligning,,you have to align the fronts with the rears.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #482525 Tue Dec 15 2015 7:29pm
jochem00
the rears are dead centre 0 toe in
Post #482526 Tue Dec 15 2015 7:32pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I would think that what Tyrefitter is on about is the front axle (tyres) aligned with the back axle.
I could be wrong but I am sure he will pop back.
Wink Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #482529 Tue Dec 15 2015 8:51pm
Tyrefitter
You need to get the settings for aligning vehicles,,just doing the fronts is ok as long as you align to rears & it's all about the thrust angle,not just measuring the fronts with a tape measure.we use to get away with that idea year ago when nearly all vehicles had a starlight beam axle but now with so many agustments you should let someone do it on a 4 wheel alignment machine to get it accurate.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #482532 Tue Dec 15 2015 9:13pm
jochem00
off course the 4 wheel alignment is the best solution but I don't have time to pass by the shop to have it done.
the tapemeasuring way should at least give an indication. yesterday the front wheels where at negative toe in.
I put the wheels at 0 toe in for the time being as I've got a long trip to do on my new winter tires and don't want to start rubbing the inside of tires straight away.
Post #482560 Wed Dec 16 2015 11:17am
Jaggs
I'm looking for 4 wheel alignment in Leeds, I've read a few previous posts and googled it which is enough to give you nightmares about people with all the gear but no idea, anyone used a company in or near Leeds and happy with the result
Post #482832 Fri Dec 18 2015 9:46pm
