![]() | Home > Wheels & Tyres > Quick wheel alignment check with measuring tape |
Its not just the fronts you need aligning,,you have to align the fronts with the rears.
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 ![]() |
the rears are dead centre 0 toe in |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 ![]() ![]() ![]() |
I would think that what Tyrefitter is on about is the front axle (tyres) aligned with the back axle.
You need to get the settings for aligning vehicles,,just doing the fronts is ok as long as you align to rears & it's all about the thrust angle,not just measuring the fronts with a tape measure.we use to get away with that idea year ago when nearly all vehicles had a starlight beam axle but now with so many agustments you should let someone do it on a 4 wheel alignment machine to get it accurate.
off course the 4 wheel alignment is the best solution but I don't have time to pass by the shop to have it done.
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
I'm looking for 4 wheel alignment in Leeds, I've read a few previous posts and googled it which is enough to give you nightmares about people with all the gear but no idea, anyone used a company in or near Leeds and happy with the result |
