Home > Faults & Fixes > Brake caliper issue
dux
With the Brembo's it's just one unit.
The calipers don't sit inside the carrier like normal brakes. It is one large unit held by two bolts.
Unfortunately I cannot message Bodsy or Discomike yet, as I'm a new member..
Post #504086 Tue Aug 30 2016 12:18pm
Williamsboy
Wales 2005 Range Rover Sport TDV6 HSE Rimini Red
Ok mate, i will try and message them and hopefully they can reply directly to yourself.
All the best
Mike
Post #504182 Wed Aug 31 2016 10:54am
Bodsy
Site Sponsor
Here you go. Thumbs Up
 Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #504200 Wed Aug 31 2016 12:38pm
dux
Thank you both.
Appreciate you taking the time.
Post #504202 Wed Aug 31 2016 1:16pm
Williamsboy
brembo caliper torque
Thanks Bodsy, you truly are a knight in shining armour. Hope all goes well Dux with the calipers etc.
Regards
Mike
Post #504217 Wed Aug 31 2016 4:56pm
dux
Yup. Fronts are both done.
Super easy setup.
Cleaned, scrubbed and greased everything.
Torqued all bolts to perfection.
Now starting the rears, but need those specs as well. Rolling Eyes
Post #504257 Wed Aug 31 2016 11:21pm
dux
Not sure if these values also apply to the rear of a 2012 RRS SC
Post #504258 Wed Aug 31 2016 11:30pm
Williamsboy
Hi Dux, I believe the rear calipers are the same on the rear for RRS S/C and standard RRS. Brembo's only fitted to the front i would assume.. But to be on the safe side i will ask Bodsy.
Regards
MIke
Post #504281 Thu Sep 01 2016 10:52am
Bodsy
Site Sponsor
Rears the same as std as far as torque settings concerned. Thumbs Up
Same as in the brake bible. Bodsys Brake Bible
See it HERE
Post #504282 Thu Sep 01 2016 11:02am
dux
Thank you.
Post #504291 Thu Sep 01 2016 1:19pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
DUX, that is about the torque setting for the caliper bracket . DO NOT use this kind of torque on the caliper fittings (sliders) . you will ruin them if possible at all!!
I do no know the exact torque specs of these bolts (14 metric), but must be are around 60 Nm or less I would guess.
Post #504292 Thu Sep 01 2016 1:35pm
Hog
35 Nm I see now
Post #504318 Thu Sep 01 2016 8:40pm
dux
I used 26 Ft-lbs (35 Nm) for the sliders.
Post #504378 Fri Sep 02 2016 2:22pm
