![]() | Home > Faults & Fixes > Brake caliper issue |
dux Member Since: 30 Aug 2016 Location: Fla Posts: 7 ![]() |
With the Brembo's it's just one unit.
Williamsboy Member Since: 31 Dec 2014 Location: south wales Posts: 44 ![]() ![]() ![]() |
Ok mate, i will try and message them and hopefully they can reply directly to yourself.
Here you go. |
Thank you both.
Yup. Fronts are both done.
Not sure if these values also apply to the rear of a 2012 RRS SC
Hi Dux, I believe the rear calipers are the same on the rear for RRS S/C and standard RRS. Brembo's only fitted to the front i would assume.. But to be on the safe side i will ask Bodsy.
Rears the same as std as far as torque settings concerned. |
Thank you. |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
DUX, that is about the torque setting for the caliper bracket . DO NOT use this kind of torque on the caliper fittings (sliders) . you will ruin them if possible at all!!
35 Nm I see now |
I used 26 Ft-lbs (35 Nm) for the sliders. |
