Home > Faults & Fixes > Engine fault Special programs off appears when accelerating
savster
Hi all
I drive a RRS 2006 SE 2.7
Just wondering if anyone else has had the same issue as me: When I accelerate the car on a bank or quickly accelerate to go over 60 - 70mph, my dashboard alerts me and displays the message Engine Fault; Special Programs Off. There is a considerable drop in power and the car decelerates to around 30mph, despite the accelerate pedal being pushed right down to the floor.
When I stop the car and switch the ignition off and then back on again, the message disappears and the car seems to have its power back again.
Does anyone else have a similar issue? I'd be grateful if you could advise me what to do. Thanks
Post #479844 Sat Nov 14 2015 9:42pm
Camelrock
Fault codes need to be read, I would change the fuel filter first though.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #479862 Sat Nov 14 2015 10:51pm
Lost for Words
^^^^ +1. Fuel filter is a likely culprit. Thumbs Up Visiting from DISCO3.CO.UK
Post #479884 Sun Nov 15 2015 10:07am
Wogger03
I have just bought a 55 plate rrs and I'm having the exact same issues, iv got the car booked in next week to be checked over by a Landrover specialist. Not a great start to Landrover ownership! I knew I'd have issues just thought I'd go longer then a day!
Post #491176 Thu Mar 17 2016 11:01pm
Camelrock
Take it back to ware you got it from and let them sort it.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #491178 Thu Mar 17 2016 11:21pm
Wogger03
That's the plan, it only does it after accelerating hard a couple of times, then special programs message pings up along with engine fault Big Cry the lights on the special programs dial turn off then it drives fine Censored
Post #491187 Fri Mar 18 2016 6:27am
Camelrock
As mension end above try a new fuel filter before anything else.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #491210 Fri Mar 18 2016 12:55pm
Wogger03
Cheers mate, I have a feeling I'll be using this forum a lot haha
Post #491212 Fri Mar 18 2016 1:13pm
TenBob
I had this happen on my TDV8. Turned out to be the fuel pump failing, which somehow managed to deposit metallic particles in the fuel system. LR dealer replaced the fuel system (yep, the lot) under warranty, thankfully. I've never heard of this happening before, and neither had the dealer, so it's rare. Fingers crossed for you it's the fuel filter. TDV6 2010 HSE
TDV6 HSE - Gone
TDV8 HST - Gone
Post #491217 Fri Mar 18 2016 2:01pm
Wogger03
Let's hope so! The car had been stood a couple of weeks on the dealers yard and was very low on fuel when I collected it so with a bit of luck new filter, fresh fuel and a fuel flush might work. Rang the dealer today and he's said try it, he's going to refund me the money and if not he's going to take it back to have a look!
Post #491218 Fri Mar 18 2016 2:11pm
Socast
If they don't fix it I would give them the car back and walk away. These cars are decked out with electronics. Bushes, swing arms, bearings etc. are all (relatively) easy to replace, if you get a motor with bad electrics you may as well give up.
Post #491225 Fri Mar 18 2016 4:03pm
Donithediver
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Ah finally found someone with at least a suggestion. My 2006 sport has had this issue since purchased privately..I took in to Landrover they told me egr faulty on both sides. One 0% one 40% efficient quoted me 1000 to fix but would promise a fix. I got home popped bonnet and egr have been blanked previously. So confused.. exact same syptoms same place everyday.. One thing I have noticed is I'm getting quite a bit of black smoke when sinking the welly. But hey it does no harm to change fuel filter regardless.. brilliant site thanks
Post #491510 Mon Mar 21 2016 11:51pm
Camelrock
If no luck with the fuel filter would be checking inter cooler hoses next for both splits and collapsing.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #491513 Tue Mar 22 2016 12:31am
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
get it code read before you do anything , my guess would be split intercooler or split intercooler hose
Post #491540 Tue Mar 22 2016 3:53pm
Wogger03
Thanks for the advice guys, the Landrover blokes coming at the end of next week so hopefully he will let me know (cam belts being done to) if it's terminal and / or he finds any major issues the cars going back! Hope it's just some age related niggles and a simple fix love the car already
Post #491556 Tue Mar 22 2016 8:51pm
