Home > Faults & Fixes > Squeaking suspension at low speed.
cameroncornish
I've got squeaking suspension at low speed, any idea??? Common problem??? No knocks, just a lot of sqeaking.....
Post #479825 Sat Nov 14 2015 6:59pm
TheWojtek
ARB bushes. Cheap fix in parts, but if your car has active antiroll bars, its a PITA to replace. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #479850 Sat Nov 14 2015 10:11pm
cameroncornish
Perfect, was thinking it was that, but you guys on are have a lot more knowledge on the RR's than I do.
I'll have to get underneath and have a look tomorrow and see if it's got the active arb.
Was it an optional extra to have an active system fitted?? Or was it part of a package you bough with certain spec or engines?
Post #479855 Sat Nov 14 2015 10:18pm
TheWojtek
Stock on all Supercharged and TDV8, optional extra on TDV6 from 2008 on, I believe. Regards etc.,
Wojtek
Post #479867 Sun Nov 15 2015 1:24am
cameroncornish
Yeah, found it, it has got it fitted.
New polybushes for the anti roll bar ordered. Smile
Post #479876 Sun Nov 15 2015 9:51am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Don't fit polybushes they don't work as well as the standard ones from Land Rover, I speak from experience..
Post #479916 Sun Nov 15 2015 2:52pm
cameroncornish
Really?!?! Why's that? What happened? I ordered the set last night, but can always send them back....
Post #479919 Sun Nov 15 2015 3:17pm
1JBS
http://www.rrsport.co.uk/forum/topic38598.html?highlight=polybush
Hope this helps..
Post #479980 Mon Nov 16 2015 8:30am
The squeak could be the upright/hub bushes (where the wishbones meet the upright/hub). Mine had one a month or two ago and another has started to squeak now. 2012 SDV6 - it's missing a couple of cylinders
Post #479990 Mon Nov 16 2015 10:15am
B9BS X
The poly's will give a bumpier harder ride, I'd advice sticking to stock Very Happy
Propshaft also has to come out to get one of the bolts out, balls ache of a job lol but will be worth not hearing the squeeky noise again Rolling with laughter RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #480315 Wed Nov 18 2015 6:45pm
Andym418
United Kingdom 2008 Range Rover Sport TDV8 HST Lugano Teal
Check anti roll bar drop links too as I thought was my bushes changed them and still creaked. Turned out to be drop links which were so much easier wish I'd checked them first
Post #480442 Thu Nov 19 2015 10:01pm
Deuchars
Wales 2008 Range Rover Sport Supercharged HSE Stornoway Grey
I had a similar squeaking noise from the suspension on my supercharged, it got very embarrassing around town! I had the ARB bushes and drop links replaced by my local indie, £220 all in. Not to bad I though. No more squeaks, or clunks Smile 2008 Supercharged Stornaway Grey, 22inch black Stormers
Full led light pack, HST front grill, black lettering....
Great to be back on Petrol.....
Mini Cooper SD......New arrival
Nissan Navarra....gone
Mercedes C320 cdi...gone
Mini Cooper D....
Subaru Impreza Sti....gone
Land Rover Discovery....gone
Many more over the years...all gone...
Post #480463 Fri Nov 20 2015 7:43am
