Home > Faults & Fixes > Squeaking suspension at low speed. |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
ARB bushes. Cheap fix in parts, but if your car has active antiroll bars, its a PITA to replace. Regards etc.,
Sat Nov 14 2015 10:11pm |
cameroncornish Member Since: 14 Nov 2015 Location: Surrey Posts: 26 |
Perfect, was thinking it was that, but you guys on are have a lot more knowledge on the RR's than I do.
Sat Nov 14 2015 10:18pm |
Stock on all Supercharged and TDV8, optional extra on TDV6 from 2008 on, I believe. Regards etc.,
Sun Nov 15 2015 1:24am |
Yeah, found it, it has got it fitted.
Sun Nov 15 2015 9:51am |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Don't fit polybushes they don't work as well as the standard ones from Land Rover, I speak from experience.. |
Sun Nov 15 2015 2:52pm |
Really?!?! Why's that? What happened? I ordered the set last night, but can always send them back.... |
Sun Nov 15 2015 3:17pm |
http://www.rrsport.co.uk/forum/topic38598.html?highlight=polybush
Mon Nov 16 2015 8:30am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 |
The squeak could be the upright/hub bushes (where the wishbones meet the upright/hub). Mine had one a month or two ago and another has started to squeak now. 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 16 2015 10:15am |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
The poly's will give a bumpier harder ride, I'd advice sticking to stock
Wed Nov 18 2015 6:45pm |
Andym418 Member Since: 16 Sep 2015 Location: South Yorkshire Posts: 9 |
Check anti roll bar drop links too as I thought was my bushes changed them and still creaked. Turned out to be drop links which were so much easier wish I'd checked them first |
Thu Nov 19 2015 10:01pm |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 |
I had a similar squeaking noise from the suspension on my supercharged, it got very embarrassing around town! I had the ARB bushes and drop links replaced by my local indie, £220 all in. Not to bad I though. No more squeaks, or clunks 2008 Supercharged Stornaway Grey, 22inch black Stormers
Fri Nov 20 2015 7:43am |
