![]() | Home > Faults & Fixes > Squeaking suspension at low speed. |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
ARB bushes. Cheap fix in parts, but if your car has active antiroll bars, its a PITA to replace. Regards etc.,
cameroncornish Member Since: 14 Nov 2015 Location: Surrey Posts: 26 ![]() ![]() ![]() |
Perfect, was thinking it was that, but you guys on are have a lot more knowledge on the RR's than I do.
Stock on all Supercharged and TDV8, optional extra on TDV6 from 2008 on, I believe. Regards etc.,
Yeah, found it, it has got it fitted.
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Don't fit polybushes they don't work as well as the standard ones from Land Rover, I speak from experience.. |
Really?!?! Why's that? What happened? I ordered the set last night, but can always send them back.... |
http://www.rrsport.co.uk/forum/topic38598.html?highlight=polybush
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 ![]() ![]() ![]() |
The squeak could be the upright/hub bushes (where the wishbones meet the upright/hub). Mine had one a month or two ago and another has started to squeak now. 2012 SDV6 - it's missing a couple of cylinders
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
The poly's will give a bumpier harder ride, I'd advice sticking to stock |
Andym418 Member Since: 16 Sep 2015 Location: South Yorkshire Posts: 9 ![]() ![]() ![]() |
Check anti roll bar drop links too as I thought was my bushes changed them and still creaked. Turned out to be drop links which were so much easier wish I'd checked them first |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 ![]() ![]() ![]() |
I had a similar squeaking noise from the suspension on my supercharged, it got very embarrassing around town! I had the ARB bushes and drop links replaced by my local indie, £220 all in. Not to bad I though. No more squeaks, or clunks |
