Home > Technical > suspension fault code
simbad111
Hi guys, had a suspension fault light up on dash this week, normal ride only, popped car into local garage who I happen to know the boss and gave me free code reading check, the fault cade which appeared on the computer is as follows, C1A20-64, pressure increase too slow when filling reservoir, signal plausibility failure, any ideas guys what and where to start checking first before getting it checked over at dealers, copy of read out in gallery,, thanks guys
Post #479722 Fri Nov 13 2015 4:46pm
Disco_Mikey
Bust compressor dryer cap, most likely Thumbs Up
Post #479732 Fri Nov 13 2015 6:33pm
simbad111
Thanks Disco_Mikey, Had a quick look this morning removed compressor plastic cover to exposes the compressor and with spray bottle and soapy water found that there is a leak in-between the red and blue 6mm push in fittings, it would be a cheaper fix just to buy the end cap but looking at the state of the compressor it may be that trying to remove the pins would be nightmare, i may as well bite the bullet and by new compressor, the part number on the pump is as follows RQG500080, would this be the an a Hitachi pump, or is there an alternative one which would fit, [/list]
Post #479781 Sat Nov 14 2015 12:27pm
Disco_Mikey
The cap is available from a popular auction site for £30 or so.
However, the compressors tend to last another 6 months or so after fitting
You can replace with the original Hitachi, the cheaper Dunlop, or the superior AMK, the latter of which requires a software update to work Thumbs Up
I only fit the AMK units now, they have proven themselves to be fairly reliable
Post #479783 Sat Nov 14 2015 12:43pm
simbad111
compressor heat
hi guys changed compressors today after finding the old one had split on end cap and split on opposite end, fitting new one got rid of fault code but I need to ask question regarding compressor heat, when removing old one I had to cut the pipes which I could remove from old push fit connectors used some straight connectors to connect back to the new one, and connected nylon pipes to compressor, but after around 5 mins of testing compressor I noticed how hot the new compressor was and it stated to make the directly pipes soft, should the compressor get this hot or is there another fault, thanks guys
Post #480592 Sat Nov 21 2015 4:04pm
pomistea
Ireland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi-
I'm having the same issue, except my 2012 RRS has an AMK compressor.
"Reservoir taking too long to fill".
Are there ways of checking the AMK compressors and the actual reservoir itself?
Post #625733 Fri Jul 29 2022 11:12am
