Home > Technical > White smoke on idle |
MattMatt Member Since: 14 May 2015 Location: Swindon -ish Posts: 37 |
The RRS 2.7 creates loads of white smoke when it has idled for a while in a queue or such like. It clears after a bit when you move off. It doesn't smell of oil and I'm not losing any coolant so I presume it's unburnt fuel. What causes this? |
Tue Nov 10 2015 12:46pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Normally, worn injectors
Tue Nov 10 2015 12:53pm |
Thanks for the quick reply - it's done 106K. I'll try some quality cleaner but is changing the injectors a DIY project? I have Nanocom |
Tue Nov 10 2015 1:28pm |
Just taken some video of Nanocom showing injector levels.
Fri Nov 27 2015 1:48pm |
Gonna answer my owner question I think. I found DiscoMikey's excellent thread about changing injectors over the on the Disco3 site and then onto Steve Norman's stuff about values etc. Looks like the ECU lowers the good injectors to compensate for the high ones. Might change the worst two and see if it helps
Fri Nov 27 2015 5:31pm |
For starters, I would be replacing 3,4 and 5
Fri Nov 27 2015 9:27pm |
