Home > Technical > White smoke on idle
MattMatt
United Kingdom 2007 Range Rover Sport TDV6 HSE Zambezi Silver
White smoke on idle
The RRS 2.7 creates loads of white smoke when it has idled for a while in a queue or such like. It clears after a bit when you move off. It doesn't smell of oil and I'm not losing any coolant so I presume it's unburnt fuel. What causes this?
Post #479337 Tue Nov 10 2015 12:46pm
Disco_Mikey
Normally, worn injectors
How many miles has the car done?
Post #479338 Tue Nov 10 2015 12:53pm
MattMatt
Thanks for the quick reply - it's done 106K. I'll try some quality cleaner but is changing the injectors a DIY project? I have Nanocom
Post #479342 Tue Nov 10 2015 1:28pm
MattMatt
Just taken some video of Nanocom showing injector levels.
Typically the injectors are reading as follows
1. 660
2. 605
3. 1348
4. 1396
5. 1393
6. 1181
The balance faults are showing as:
P02AA Cyl 5 fuel trim at max (perm)
P02A7 Cyl 4 fuel trim at min (perm)
P029B Cyl 1 fuel trim at min (int)
P029E Cyl 2 fuel trim at max (int)
P02A2 Cyl 3 fuel trim at max (int)
P02AE Cyl 6 fuel trim at max (int)
I am assuming Injector 4 and 5 are well worn and need replacing? Do I bit the bullet and do 3 & 6 as well?
Post #481018 Fri Nov 27 2015 1:48pm
MattMatt
Gonna answer my owner question I think. I found DiscoMikey's excellent thread about changing injectors over the on the Disco3 site and then onto Steve Norman's stuff about values etc. Looks like the ECU lowers the good injectors to compensate for the high ones. Might change the worst two and see if it helps
http://www.disco3.co.uk/forum/topic126044.html = DiscoMikey thread
http://www.disco3.co.uk/forum/topic100709.html = read Steve's post
Post #481033 Fri Nov 27 2015 5:31pm
Disco_Mikey
For starters, I would be replacing 3,4 and 5
But in all reality, you will most likely end up replacing the other 3...
Post #481057 Fri Nov 27 2015 9:27pm
