![]() | Home > Technical > White smoke on idle |
MattMatt Member Since: 14 May 2015 Location: Swindon -ish Posts: 37 ![]() ![]() ![]() |
The RRS 2.7 creates loads of white smoke when it has idled for a while in a queue or such like. It clears after a bit when you move off. It doesn't smell of oil and I'm not losing any coolant so I presume it's unburnt fuel. What causes this? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
Normally, worn injectors
Thanks for the quick reply - it's done 106K. I'll try some quality cleaner but is changing the injectors a DIY project? I have Nanocom |
Just taken some video of Nanocom showing injector levels.
Gonna answer my owner question I think. I found DiscoMikey's excellent thread about changing injectors over the on the Disco3 site and then onto Steve Norman's stuff about values etc. Looks like the ECU lowers the good injectors to compensate for the high ones. Might change the worst two and see if it helps
For starters, I would be replacing 3,4 and 5
