Home > In Car Electronics > Lost all audio
mr_spaceuk
Lost all audio
Had a strange moment yesterday when I started the car, there was no sound from the speakers on any input, FM, CD, etc and the satnav screen was stuck on the Land Rover symbol.
Its ok now, but no idea what happened.
Not muted or anything so a bit of a strange one.
Post #478447 Sun Nov 01 2015 8:27pm
Lost for Words
These things can happen from time to time - usually either time, a battery disconnection or hard reset will sort them if needed. I would check your battery (and alternator) voltage though. Thumbs Up Visiting from DISCO3.CO.UK
Post #478487 Mon Nov 02 2015 8:45am
TWINSCREW
I have had this before (3 times) and is a precursor to the battery going flat soon after. My car is currently in the dealers to have a battery drain fault investigated.
Post #478792 Wed Nov 04 2015 1:24pm
Deuchars
Wales 2008 Range Rover Sport Supercharged HSE Stornoway Grey
I have a similar problem. The Land Rover symbol stays on the parents when I start the car, No Sat nav or 4x4 info screen available. In fact, the buttons will not do anything. Sometimes it comes on and the Sat nav works, but the 4x4 info never does anything, it's like it's not reading the info. Used to work, now it doesn't! I've had a software upgrade done, tried a hard reset, still not right. My battery is new and the charge is good. My local indie is looking into it, but he's at a loss and is looking for ideas. H should point out that he is a Land Rover trained mechanic, level 4 Master Technician, and has access to all the Land Rover software and diagnostics. Any help much appreciated........ 2008 Supercharged Stornaway Grey, 22inch black Stormers
Full led light pack, HST front grill, black lettering....
Great to be back on Petrol.....
Mini Cooper SD......New arrival
Nissan Navarra....gone
Mercedes C320 cdi...gone
Mini Cooper D....
Subaru Impreza Sti....gone
Land Rover Discovery....gone
Many more over the years...all gone...
Post #478873 Wed Nov 04 2015 10:22pm
Lost for Words
Have you tried cleaning the disc and/or drive? Visiting from DISCO3.CO.UK
Post #478898 Thu Nov 05 2015 9:39am
TWINSCREW
I will let you know the outcome from the dealer, not holding my breath.
Friday 6th Nov, latest this morning, they are going to fit a new alternator, hope to get the car back tomorrow.
Post #478920 Thu Nov 05 2015 12:55pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Just put a new battery on our 2011 RRS and the audio is playing up. Please advise how I should do a hard reset?
Post #479042 Sat Nov 07 2015 12:31am
Lost for Words
http://www.disco3.co.uk/wiki/Hard_Reset Thumbs Up Visiting from DISCO3.CO.UK
Post #479054 Sat Nov 07 2015 9:23am
fdhadi
Thanks Lost for Words. Thumbs Up
Post #479057 Sat Nov 07 2015 9:40am
TWINSCREW
Update on the above, now being told it is the aerial on the roof which is the culprit for my battery drain and will be sorted by Monday. Stand by for update.
OK, got my car back tuesday and it was a fault in the aerial amplifier circuit that was causing the 2 amp drain, now been fixed and no battery drain apparent now.
Post #479065 Sat Nov 07 2015 11:24am
mr_spaceuk
interesting, I sometimes get the power save message come up, I might have to look at this.
Post #481557 Thu Dec 03 2015 5:58pm
gogsy1956
I quite often suffer from no audio,, radio, dab or cd, even when it appears to be connected to a station, then after a few minutes it returns, sometimes it takes a restart,, pain in the arse at times but wish I knew what the cause was!! 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #481573 Thu Dec 03 2015 8:32pm
