Home > Technical > Suspension problems |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 |
I had the same warning on mine. I changed the brake switch, bulbs and had a new battery all to no avail. Turned out there was a dodgy ride height sensor. Once that was swapped for a new one, No more faults appeared. Although I have noticed that I do get the HDC inactive fault flashing up if the battery charge has dropped a bit..... Very sensitive to voltage drops these Range Rover's.... 2008 Supercharged Stornaway Grey, 22inch black Stormers
Tue Nov 03 2015 8:35am |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
I do get the right drivers side wheel light flash red on the 4 x 4 screen only when I park my car round the back of my house which has a uneven level but only in that position, everywere else parked or driving the light disappears but this has been like this ever since I've owned the car an car sits level in all height positions but may still be worth changing.
Tue Nov 03 2015 9:38pm |
I wouldn't know what the 4x4 screen should display as mine isn't working and nobody can tell me why! The sensors are about £50 each and are simple to swap, 2 screws and an electrical connection to unplug. I only changed 1 and all was ok. 2008 Supercharged Stornaway Grey, 22inch black Stormers
Wed Nov 04 2015 1:06am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Matford LR were doing full kits of genuine D3/RRS height sensors for £30 on Ebay. They don't seem to be there at the moment though.
Wed Nov 04 2015 9:18am |
