Home > General (L494) > Centre console gloss black heavily scratched. |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
Go back a tell the Dealer Principle that you are not prepared to accept a premier vehicle in the condition that it has been sold to you in. Tell him that you expect the damage to be put right or you will reject the vehicle.
Mon Oct 19 2015 7:32pm |
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 |
How bad is it ? Surely it can't be that bad ?
Mon Oct 19 2015 7:35pm |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 |
Is the car new or secondhand? Typical smart-arse comments from a useless fat, dumb and happy dealer.
Mon Oct 19 2015 8:36pm |
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 |
They need to replace the panel. I had this issue on my BMW X5 there were a few panels scratched and I was told it's a second hand car and to expect this. The car had a spec that I could simply not afford to miss so I raised it with the dealer principal and all panels were replaced (cost them around £1100 apparently!). |
Tue Oct 20 2015 8:56am |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 |
I've tried various polishes on the exterior gloss and inside piano black....
Tue Oct 20 2015 1:06pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
As Mark says. It needs to be treated very gently, wiped over with a soft damp cloth.
Tue Oct 20 2015 1:07pm |
If they replace it.. enjoy it while it lasts ... because it won't !!! 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Tue Oct 20 2015 1:15pm |
bluestone Member Since: 11 Aug 2015 Location: Manchester Posts: 155 |
I remember seeing the piano black on a showroom car and the scratches were shocking to say the least. I ended up with grey oak which is a no cost option, looks fantastic, and doesn't scratch. MY16 (65) RRS, HSE, White, 21" 507s, Pan/Black Roof, 7 Seats, Ebony/Cirrus, Surround Cams, Fully Color Coded |
Tue Oct 20 2015 1:31pm |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 |
I had it on my first RRS, it got quite scratched. However I still like it so specced it again on my second. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Tue Oct 20 2015 1:53pm |
forest172 Member Since: 03 Apr 2013 Location: Derbyshire Posts: 104 |
this removes scratches from the exterior gloss with the crimson lake country pad on a DA polisher http://www.polishedbliss.co.uk/acatalog/menzerna-85re-cat8.html |
Tue Oct 20 2015 2:32pm |
mikeyross Member Since: 11 Aug 2015 Location: Brighton Posts: 41 |
Mine was perfect on handover and still good after a month or so ...
Tue Oct 20 2015 4:57pm |
I've got Menzerna SF4000 ... close enough ...i'll use the DA and a small pad next time .. 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's 2013 Porsche Boxster S 3.4 2014 Audi A3 S line Quattro --------------------------------- |
Tue Oct 20 2015 6:31pm |
JasSmiths Member Since: 28 Dec 2014 Location: Staffordshire Posts: 53 |
Genuinely thinking about putting Gyeon MOHS on mine.... First time applying a Quartz coating to the inside of a car! |
Tue Oct 20 2015 6:57pm |
chatuge Member Since: 04 Feb 2015 Location: West Sussex Posts: 60 |
Could you send pic of the Grey Oak as considering this on one I've just been offered from Dealer which is a cancelled order. |
Tue Oct 20 2015 7:32pm |
