Home > General (L494) > Centre console gloss black heavily scratched.
Theboyleach
Hi
Bought my RR sport on Saturday.
I pointed out to the dealer that the high gloss black centre console (cup holder slider as well) is heavily scratched. He said most are!
Does anyone know of a way to remove these scratches?
A mild abrasive/polish?
Thanks
Post #477071 Mon Oct 19 2015 6:51pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Go back a tell the Dealer Principle that you are not prepared to accept a premier vehicle in the condition that it has been sold to you in. Tell him that you expect the damage to be put right or you will reject the vehicle.
You have not bought an old banger from the auctions. An L494 should be sold to you in as new showroom condition.
Just my thoughts. Anyone else care to offer their opinion?
Jim
Post #477079 Mon Oct 19 2015 7:32pm
GJW1
How bad is it ? Surely it can't be that bad ?
It doesn't sound good from what your saying any photos ?
Post #477080 Mon Oct 19 2015 7:35pm
Mark_N
Is the car new or secondhand? Typical smart-arse comments from a useless fat, dumb and happy dealer.
I'm afraid the piano black finish is a nightmare. Even if perfect from new, it will not stay that way. I mentioned it to an LR valeter at Goodwood and he pulled a face, admitting it was a problem. The only way high gloss black is ever durable is if it's made of something like glass. A normal paint finish is simply not hard enough.
The message is clear. If you are specifying a new RRS, do NOT go for the piano black option... Mark
SVR in Estoril Blue Thumbs Up
Post #477085 Mon Oct 19 2015 8:36pm
RRSman
They need to replace the panel. I had this issue on my BMW X5 there were a few panels scratched and I was told it's a second hand car and to expect this. The car had a spec that I could simply not afford to miss so I raised it with the dealer principal and all panels were replaced (cost them around £1100 apparently!).
Post #477128 Tue Oct 20 2015 8:56am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
I've tried various polishes on the exterior gloss and inside piano black....
Nothing seems to work to well... I did try a bit of Autoglym SRP which has fillers and it sure made the piano swirls look better
Keep hearing people suggest Poor boys Black hole though....may be worth a try 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #477139 Tue Oct 20 2015 1:06pm
SVR575
As Mark says. It needs to be treated very gently, wiped over with a soft damp cloth.
Should definitely be changed though. SVR 2018 in Santorini Black.
Post #477140 Tue Oct 20 2015 1:07pm
andman
If they replace it.. enjoy it while it lasts ... because it won't !!! Laughing 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #477143 Tue Oct 20 2015 1:15pm
bluestone
I remember seeing the piano black on a showroom car and the scratches were shocking to say the least. I ended up with grey oak which is a no cost option, looks fantastic, and doesn't scratch. MY16 (65) RRS, HSE, White, 21" 507s, Pan/Black Roof, 7 Seats, Ebony/Cirrus, Surround Cams, Fully Color Coded
Post #477144 Tue Oct 20 2015 1:31pm
Chrisr1806
I had it on my first RRS, it got quite scratched. However I still like it so specced it again on my second. Embarassed Whistle Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... Twisted Evil
Gone but not forgotten:
2014 RRS2 SDV6 HSE in Loire Blue
2011 Freelander 2 SD4 HSE in Santorini Black
Post #477145 Tue Oct 20 2015 1:53pm
forest172
this removes scratches from the exterior gloss with the crimson lake country pad on a DA polisher
http://www.polishedbliss.co.uk/acatalog/menzerna-85re-cat8.html
Post #477148 Tue Oct 20 2015 2:32pm
mikeyross
Mine was perfect on handover and still good after a month or so ...
There was a nasty scratch on the aluminium 'hockey stick' next to it, however ... That is getting replaced, along with a faulty roof rail gutter insert thing ...
So, get it sorted - the car must be perfect on handover!
Post #477173 Tue Oct 20 2015 4:57pm
andman
I've got Menzerna SF4000 ... close enough ...i'll use the DA and a small pad next time .. 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #477190 Tue Oct 20 2015 6:31pm
JasSmiths
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Genuinely thinking about putting Gyeon MOHS on mine.... First time applying a Quartz coating to the inside of a car! Rolling with laughter Laughing
Post #477198 Tue Oct 20 2015 6:57pm
chatuge
Could you send pic of the Grey Oak as considering this on one I've just been offered from Dealer which is a cancelled order.
Post #477205 Tue Oct 20 2015 7:32pm
