Home > General > new Battery
Disco_Mikey
It is a myth. The car "wakes" every 2 hours to check it is level (and adjust if req) regardless of its ride height Thumbs Up
Post #476713 Sat Oct 17 2015 6:02am
jenko2005
Wales 2006 Range Rover Sport Supercharged Zambezi Silver
Would this battery also be ok for the 4.2 SC
Post #476909 Sun Oct 18 2015 12:42pm
Disco_Mikey
Yes, it will.
It's a much higher rating than is needed, but that's not a bad thing Thumbs Up
Post #476966 Sun Oct 18 2015 8:13pm
mnk
I have this battery for sell. Used for 2months and now 5months old
Post #476971 Sun Oct 18 2015 8:44pm
jenko2005
Thanks Disco for confirming
Post #476972 Sun Oct 18 2015 8:49pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Another Tayna promo code
FACEBOOK45
I'm not sure what the discount is but worth a try if you need a new Battery.
Don't forget to try DM's code as I'm not sure which of the 2 is best.
D2BOYS
Post #498432 Sat Jun 11 2016 8:20am
uu__26
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
With regards to swapping out the battery, the only info I can find is the 2 pages in the manual, can't find anything online, just says to turn key to position II, apply park brake, remove key and wait at least two minutes, then remove negative, then positive, the install new battery, attached positive, then negative, done.
Any other recommendations/advice before giving it a go!!
Post #498930 Sat Jun 18 2016 10:00am
Paddi
Yes -- cover the nearside wing with something like a big towel to protect the paintwork. The battery is very heavy and awkward to lift out so if you have a bad back or any problems with arms or shoulders get someone else to do it! 2008 MY Java Black TDV8 HSE
Post #498932 Sat Jun 18 2016 10:27am
uu__26
Cheers, looks awkward, but thankfully not as awkward as on a Vogue, I saw a video where they had to put the bonnet at 90 degrees to get the thing out!
Post #498934 Sat Jun 18 2016 10:46am
Be careful when you put the battery in - the engine ECU and TCM are just behind the battery box! 2012 SDV6 - it's missing a couple of cylinders
Post #498946 Sat Jun 18 2016 1:07pm
uu__26
Thanks for the heads up, I think I'm going to save it for tomorrow when I'm feeling less worse for wear...
Post #498948 Sat Jun 18 2016 1:12pm
