Home > General > new Battery |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
It is a myth. The car "wakes" every 2 hours to check it is level (and adjust if req) regardless of its ride height |
Sat Oct 17 2015 6:02am |
jenko2005 Member Since: 29 Jul 2014 Location: Rhoose Posts: 142 |
Would this battery also be ok for the 4.2 SC |
Sun Oct 18 2015 12:42pm |
Yes, it will.
Sun Oct 18 2015 8:13pm |
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 |
I have this battery for sell. Used for 2months and now 5months old |
Sun Oct 18 2015 8:44pm |
Thanks Disco for confirming |
Sun Oct 18 2015 8:49pm |
uu__26 Member Since: 30 May 2016 Location: Surbiton Posts: 26 |
With regards to swapping out the battery, the only info I can find is the 2 pages in the manual, can't find anything online, just says to turn key to position II, apply park brake, remove key and wait at least two minutes, then remove negative, then positive, the install new battery, attached positive, then negative, done.
Sat Jun 18 2016 10:00am |
Yes -- cover the nearside wing with something like a big towel to protect the paintwork. The battery is very heavy and awkward to lift out so if you have a bad back or any problems with arms or shoulders get someone else to do it! 2008 MY Java Black TDV8 HSE
Sat Jun 18 2016 10:27am |
Cheers, looks awkward, but thankfully not as awkward as on a Vogue, I saw a video where they had to put the bonnet at 90 degrees to get the thing out! |
Sat Jun 18 2016 10:46am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Be careful when you put the battery in - the engine ECU and TCM are just behind the battery box! 2012 SDV6 - it's missing a couple of cylinders
Sat Jun 18 2016 1:07pm |
Thanks for the heads up, I think I'm going to save it for tomorrow when I'm feeling less worse for wear... |
Sat Jun 18 2016 1:12pm |
