Home > Technical > Replace or charge Battery |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Get it on the charge overnight. No need to disconnect anything, but make sure the negative cable's on the ground point, not the terminal.
Wed Sep 30 2015 4:47pm |
Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285 |
Ground point, where is that? Why is it different to terminal?
Wed Sep 30 2015 4:51pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
With Winter coming buy new AGM Battery Varta/Bosch G14 £140.00 put on yourself job done and forget about it. Don't worry about Battery Monitoring System just make sure battery is fully charged before you fit it.
Wed Sep 30 2015 4:58pm |
There are ground points on the body just in front of the engine bay fusebox. It needs to be used so the Battery Monitoring System will see the charge - using the terminal would bypass this. Visiting from DISCO3.CO.UK
Wed Sep 30 2015 5:00pm |
@ Lost for Words, will take a look to see if I can find them, thanks.
Wed Sep 30 2015 5:13pm |
Hi
Wed Sep 30 2015 5:26pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Most original landrover batteries are wet cell type's,,,, unscrew the caps and make sure the cells are topped up. I have been caught out in the past sitting with the radio on for an hour resulting in a flat battery.
Wed Sep 30 2015 5:36pm |
You need an AGM one like these: https://www.tayna.co.uk/019-AGM-Car-Batteries-G414.html (PS: Try "D2BOYS" discount code. ) Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Wed Sep 30 2015 6:06pm |
Okay, so had it on charge all day today, found the ground points, thanks Lost for Words.
Thu Oct 01 2015 5:22pm |
No problem Richhad
Lost for Words Just as a point of interest, if a CETK battery charger were to be hard wired in where would the negative connection need to be made, the negative terminal or one of the earth points? Cheers Col |
Thu Oct 01 2015 5:49pm |
Essentially any ground point will do as long as it's not the terminal. Visiting from DISCO3.CO.UK
Thu Oct 01 2015 6:00pm |
Fri Oct 02 2015 2:00pm |
Always negative then positive to disconnect, and reverse to reconnect; the reason for this is that the negative side of the battery is grounded to the bodywork - touch the body and the positive terminal to undo it and...
Fri Oct 02 2015 2:14pm |
Thanks Lost for Words, so disconnect Neg first, then Positive, wrap pos lead in cloth as someone on here suggested to prevent it touching any metalwork.
Fri Oct 02 2015 2:35pm |
