![]() | Home > Technical > Replace or charge Battery |
Get it on the charge overnight. No need to disconnect anything, but make sure the negative cable's on the ground point, not the terminal. |
Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285 ![]() ![]() |
Ground point, where is that? Why is it different to terminal?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
With Winter coming buy new AGM Battery Varta/Bosch G14 £140.00 put on yourself job done and forget about it. Don't worry about Battery Monitoring System just make sure battery is fully charged before you fit it.
There are ground points on the body just in front of the engine bay fusebox. It needs to be used so the Battery Monitoring System will see the charge - using the terminal would bypass this. |
@ Lost for Words, will take a look to see if I can find them, thanks.
Hi
Most original landrover batteries are wet cell type's,,,, unscrew the caps and make sure the cells are topped up. I have been caught out in the past sitting with the radio on for an hour resulting in a flat battery.
You need an AGM one like these: https://www.tayna.co.uk/019-AGM-Car-Batteries-G414.html ![]() (PS: Try "D2BOYS" discount code. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Okay, so had it on charge all day today, found the ground points, thanks Lost for Words.
No problem Richhad
Lost for Words Just as a point of interest, if a CETK battery charger were to be hard wired in where would the negative connection need to be made, the negative terminal or one of the earth points? Cheers Col |
Essentially any ground point will do as long as it's not the terminal. |
Always negative then positive to disconnect, and reverse to reconnect; the reason for this is that the negative side of the battery is grounded to the bodywork - touch the body and the positive terminal to undo it and... |
Thanks Lost for Words, so disconnect Neg first, then Positive, wrap pos lead in cloth as someone on here suggested to prevent it touching any metalwork.
