Home > Maintenance & Modifications > Brembo six piston calipers
RR-CBY
Hi Guys
I have got MY2010 TDV8 Sport and I have just bought a set of front brembo 6 pot calipers off a new shape sport as an upgrade, can anybody tell me what size discs I need to buy and also can I use the existing brake pad wear indicator or are they different for the brembo calipers?
Also are the caliper mounting bolts the same for the brembo caliper and standard calipers, I know from experience that brembo calipers for the Subaru are different bolts than the standard calipers
Just trying to get everything sorted so l can fit them
Thanks in advance
Carl
Post #474473 Sun Sep 27 2015 2:29pm
Lost for Words
PN for discs is LR016176. Pretty sure bolts are the same. Wear sensor is different - LR019401. Thumbs Up Visiting from DISCO3.CO.UK
Post #474476 Sun Sep 27 2015 2:52pm
Discs are 380mm Dia. I think the Calliper Mtg. bolts are the same but the wear sensor is different.
Brake disc Part Number could be LR027106 Microcat say's refer to Tech Bulletin LTB00317/LTB00326 before ordering.
I think it depends on VIN number.
Post #474477 Sun Sep 27 2015 2:52pm
Hi
Would appear those TSB's refer to issues you may have with vibration under braking so I guess in your case they do not apply.
Post #474480 Sun Sep 27 2015 3:16pm
Disco_Mikey
Caliper bolts are the same
Discs are 380mm
Back plates are different. OR they can be removed altogether
Wear sensor is different, but can be re-used
Flexi pipes can be re-used
You will need a minimum of 20" wheels to clear the calipers
Just put them onto my Disco 3. They are incredible Bow down
Post #474483 Sun Sep 27 2015 3:59pm
RR-CBY
Thanks for the reply's guys I'll get some discs and a wear sensor ordered then Thumbs Up
Post #474484 Sun Sep 27 2015 3:59pm
RR-CBY
Disco Mikey, do you know what size disc is already on the MY2010 TDV8? As the existing back plate is approx 20mm bigger than the existing disc so was hoping I could still use them? If not have you got a part number for the back plates I would need?
Thanks
Carl
Post #474486 Sun Sep 27 2015 4:04pm
Disco_Mikey
4 pot Brembos are 360mm
Backplates may well be the same on the 2010 RRS..
Post #474507 Sun Sep 27 2015 6:39pm
Looking at the Parts List for the 2010 on RRS they appear to be the same LR013665 and LR013666 however suggest you check with dealer just to confirm.
Check on Flea-Bay someone selling a pair of New Genuine Discs for £99.00 + p&p sounds like a good price.
http://www.ebay.co.uk/itm/RANGE-ROVER-RANG...3ab234318c
Post #474512 Sun Sep 27 2015 6:56pm
RR-CBY
Cheers for that Col Thumbs Up yeah I had already spotted them discs on eBay and I've sent him a message just to confirm they are the 380mm diameter discs
Post #474517 Sun Sep 27 2015 7:18pm
RR-CBY
As a back up I've also found these on eBay
What do people recommend? Should I stick with OEM discs or are these Delphi discs just as good?[/url][/code]
Post #474519 Sun Sep 27 2015 7:29pm
Disco_Mikey
I have Delhi discs on mine, and they cost me a whole lot more than that. Make sure that is the price for a pair, or individually...
Post #474528 Sun Sep 27 2015 8:12pm
tonywolf
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Just got these bad boys, there massive :thumbs: :thumbs: Just got to find the other bits and pieces now!!
 Best Regards
Tony
MY2014 SDV6 AB Dynamic
Post #496412 Wed May 18 2016 12:44pm
http://www.ebay.co.uk/itm/RANGE-ROVER-RANG...SwgQ9ViAVv
http://www.ebay.co.uk/itm/RANGE-ROVER-RANG...SwLVZViGYu
Post #496437 Wed May 18 2016 5:26pm
tonywolf
Good price for those discs Thumbs Up Best Regards
Tony
Post #496439 Wed May 18 2016 6:02pm
