Home > Maintenance & Modifications > Brembo six piston calipers |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
PN for discs is LR016176. Pretty sure bolts are the same. Wear sensor is different - LR019401. Visiting from DISCO3.CO.UK
Sun Sep 27 2015 2:52pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Discs are 380mm Dia. I think the Calliper Mtg. bolts are the same but the wear sensor is different.
Hi
Sun Sep 27 2015 3:16pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Caliper bolts are the same
Sun Sep 27 2015 3:59pm |
RR-CBY Member Since: 28 Jan 2015 Location: Derbyshire Posts: 13 |
Thanks for the reply's guys I'll get some discs and a wear sensor ordered then |
Disco Mikey, do you know what size disc is already on the MY2010 TDV8? As the existing back plate is approx 20mm bigger than the existing disc so was hoping I could still use them? If not have you got a part number for the back plates I would need?
Sun Sep 27 2015 4:04pm |
4 pot Brembos are 360mm
Sun Sep 27 2015 6:39pm |
Looking at the Parts List for the 2010 on RRS they appear to be the same LR013665 and LR013666 however suggest you check with dealer just to confirm.
Sun Sep 27 2015 6:56pm |
Cheers for that Col yeah I had already spotted them discs on eBay and I've sent him a message just to confirm they are the 380mm diameter discs |
Sun Sep 27 2015 7:18pm |
As a back up I've also found these on eBay
Sun Sep 27 2015 7:29pm |
I have Delhi discs on mine, and they cost me a whole lot more than that. Make sure that is the price for a pair, or individually... |
Sun Sep 27 2015 8:12pm |
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 |
Just got these bad boys, there massive :thumbs: :thumbs: Just got to find the other bits and pieces now!!
Wed May 18 2016 12:44pm |
http://www.ebay.co.uk/itm/RANGE-ROVER-RANG...SwgQ9ViAVv
Wed May 18 2016 5:26pm |
Good price for those discs Best Regards
Wed May 18 2016 6:02pm |
