Home > Faults & Fixes > Constant beep when select reverse
Stacky-hst
This has happened suddenly when I select reverse it beeps constantly and the orange light flashes with the picture of the sensor near the lock unlock button problem is I have no parking sensors now and is an issue , hoping it's a quick fix anyone ?
Post #468504 Sat Jul 25 2015 8:15am
Tyrefitter
Hi,,is their anything obscuring a rear sensor.?
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #468507 Sat Jul 25 2015 8:40am
PEACHY
Common fault Big Cry either eroded electrical cable or parking sensor failed - how are you at taking bumpers off Crying or Very sad 16MY Estoril Blue SVR.............
Post #468512 Sat Jul 25 2015 9:29am
Stacky-hst
Hey guys I haven't taken a bumper off a Range Rover before but other cars is it easy ? Is the fix doable myself or Land Rover Jobby ? Thanks And no nothing's in the way of the sensor
Post #468518 Sat Jul 25 2015 11:25am
It's relatively simple. A few screws below the bumper, a couple in the wheel arch from memory. Lever the ends out to pop it off. Easier with help but ok alone. The wiring can be fixed either with a suitable butt connector or by soldering. Ensure whatever you do is protected from water ingress. I did a temporary repair on mine earlier this year and it's been fine until some recent wet weather running caused the odd error. I bought a replacement loom for about £50 and will, at some point, fit that to make a permanent repair.
I know a chap who works for the company that made/makes the looms. The replacement is not as well taped as the original and feels a bit "cheap" compared to the original. Original loom was made by the company in UK factory. The replacement is made by the company in an Egyptian factory and is labelled as such on the packaging. 2012 SDV6 - it's missing a couple of cylinders
Post #468528 Sat Jul 25 2015 2:37pm
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Im presuming that you can't tell if it is an eroded cable or the sensor itself until you get the rear bumper off?
I have an intermittent failure on mine. Weather conditions etc make no difference, dry, wet, hot, cold etc. They can work/stop working on the same journey, even on the same reversing operation. 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #469450 Tue Aug 04 2015 5:36pm
Bodsy
Site Sponsor
First pass would be to read the fault codes or look at the live values to determine which one is faulty. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #469452 Tue Aug 04 2015 5:39pm
darrenmcneill
When I've previously had my fault codes checked there wasn't anything relating to it? im presuming that you would only get a fault code when they are failing?
How do you view the live values?
Again, trying to establish which one is failing by "listening" is another hard one as the fault is so intermittent. I can go for weeks without a fault, and then it can re-occur a few times in 1 day?
Just been scouring eBay and have by chance come across a full bumper (in my colour) with 3 parking sensors already in it. I need to replace my bumper as there is a "ding" in it so may be worth an option? 2006 HSE for Sale - £7,499 (Manchester)
Post #469458 Tue Aug 04 2015 6:22pm
