Home > Faults & Fixes > Constant beep when select reverse |
Hi,,is their anything obscuring a rear sensor.?
Sat Jul 25 2015 8:40am |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 |
Common fault either eroded electrical cable or parking sensor failed - how are you at taking bumpers off 16MY Estoril Blue SVR.............
Sat Jul 25 2015 9:29am |
Stacky-hst Member Since: 01 Jul 2015 Location: Bristol Posts: 13 |
Hey guys I haven't taken a bumper off a Range Rover before but other cars is it easy ? Is the fix doable myself or Land Rover Jobby ? Thanks And no nothing's in the way of the sensor |
Sat Jul 25 2015 11:25am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 |
It's relatively simple. A few screws below the bumper, a couple in the wheel arch from memory. Lever the ends out to pop it off. Easier with help but ok alone. The wiring can be fixed either with a suitable butt connector or by soldering. Ensure whatever you do is protected from water ingress. I did a temporary repair on mine earlier this year and it's been fine until some recent wet weather running caused the odd error. I bought a replacement loom for about £50 and will, at some point, fit that to make a permanent repair.
Sat Jul 25 2015 2:37pm |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Im presuming that you can't tell if it is an eroded cable or the sensor itself until you get the rear bumper off? I have an intermittent failure on mine. Weather conditions etc make no difference, dry, wet, hot, cold etc. They can work/stop working on the same journey, even on the same reversing operation. 2006 HSE for Sale - £7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html |
Tue Aug 04 2015 5:36pm |
First pass would be to read the fault codes or look at the live values to determine which one is faulty. Bodsys Brake Bible
Tue Aug 04 2015 5:39pm |
When I've previously had my fault codes checked there wasn't anything relating to it? im presuming that you would only get a fault code when they are failing?
Tue Aug 04 2015 6:22pm |
