![]() | Home > Faults & Fixes > Constant beep when select reverse |
Hi,,is their anything obscuring a rear sensor.?
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Common fault |
Stacky-hst Member Since: 01 Jul 2015 Location: Bristol Posts: 13 ![]() ![]() |
Hey guys I haven't taken a bumper off a Range Rover before but other cars is it easy ? Is the fix doable myself or Land Rover Jobby ? Thanks And no nothing's in the way of the sensor |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9035 ![]() ![]() ![]() |
It's relatively simple. A few screws below the bumper, a couple in the wheel arch from memory. Lever the ends out to pop it off. Easier with help but ok alone. The wiring can be fixed either with a suitable butt connector or by soldering. Ensure whatever you do is protected from water ingress. I did a temporary repair on mine earlier this year and it's been fine until some recent wet weather running caused the odd error. I bought a replacement loom for about £50 and will, at some point, fit that to make a permanent repair.
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Im presuming that you can't tell if it is an eroded cable or the sensor itself until you get the rear bumper off? I have an intermittent failure on mine. Weather conditions etc make no difference, dry, wet, hot, cold etc. They can work/stop working on the same journey, even on the same reversing operation. 2006 HSE for Sale - £7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html |
First pass would be to read the fault codes or look at the live values to determine which one is faulty. Bodsys Brake Bible
When I've previously had my fault codes checked there wasn't anything relating to it? im presuming that you would only get a fault code when they are failing?
