Home > Wheels & Tyres > RRS tyres |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
You can run 255/55/19; I do just that. Make sure your insurance company is happy with it. Mine is happy. 2012 SDV6 - it's missing a couple of cylinders
Wed Jul 15 2015 9:36pm |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Hi, rather than start a new post.
Sat Aug 08 2015 2:24am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Std tyre sizes on RRS up to MY13 were 255/50 19 or 275/40 20 - the 2015 wheels you mention sound like they're off the new model and I don't know if they will fit earlier RRS Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Sat Aug 08 2015 6:45am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5024 |
I'm running 21" rims with 275/45 tyres form a 2015 car on my 12 plate S/C, they fit fine and have not had any issues. Guess I'm now tempting fate.
Sat Aug 08 2015 9:35am |
I didn't know wheels were interchangeable between RRS1 and RRS2 Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Sat Aug 08 2015 9:39am |
They fit ok. the only difference is the RRS1 wheels have a 53mm offset and the RRS2 a 49mm offset so they sit out slightly further. Have actually posted a couple of pictures previous of them fitted on the car.
Sat Aug 08 2015 10:07am |
Sat Aug 08 2015 10:29am |
Yes Muddywheels you are most likely right with your STD sizes I didn,t have any to measure up.
Sun Aug 09 2015 8:14am |
Hi
Sun Aug 09 2015 9:41am |
Yes thats right.
Sun Aug 09 2015 10:09pm |
That is A Standard 20" Rim of a RRS2. A 255/55 x 20 Tyre/Wheel combination gives a overall diameter of 789mm, a 275/45 x 21 gives a overall diameter of 781mm. which is about 1% difference. I would imagine the reason it is such a high profile tyre is so that it is has a comparable overall diameter that of the 21" option, the same as the 22" rim option probably has 40 profile. I would not think L/R will change the diff ratios depending on whether a customer has specified 20" 21" or 22" rims they would compensate with a different profile tyre.
Sun Aug 09 2015 11:21pm |
Col, thanks for the reply.
Mon Aug 10 2015 1:51am |
I wouldn't know if they changed ratios between the RRS1 and RRS2 but as I say I am running 21" rims from a RRS2 on a RRS1 and the speedo difference is with the 21" rim's at 30mph on the speedo the car is actually doing 31/32 mph. and at 70mph it is between 74/75mph. as the 275/45 x 21 and the 255/55 x 20 wheels have virtually the same overall diameter/ circumference I would have thought you would have a similar variation.
Mon Aug 10 2015 7:09am |
