![]() | Home > Wheels & Tyres > RRS tyres |
You can run 255/55/19; I do just that. Make sure your insurance company is happy with it. Mine is happy. |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Hi, rather than start a new post.
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Std tyre sizes on RRS up to MY13 were 255/50 19 or 275/40 20 - the 2015 wheels you mention sound like they're off the new model and I don't know if they will fit earlier RRS |
I'm running 21" rims with 275/45 tyres form a 2015 car on my 12 plate S/C, they fit fine and have not had any issues. Guess I'm now tempting fate.
I didn't know wheels were interchangeable between RRS1 and RRS2 |
They fit ok. the only difference is the RRS1 wheels have a 53mm offset and the RRS2 a 49mm offset so they sit out slightly further. Have actually posted a couple of pictures previous of them fitted on the car.
Yes Muddywheels you are most likely right with your STD sizes I didn,t have any to measure up.
Hi
Yes thats right.
That is A Standard 20" Rim of a RRS2. A 255/55 x 20 Tyre/Wheel combination gives a overall diameter of 789mm, a 275/45 x 21 gives a overall diameter of 781mm. which is about 1% difference. I would imagine the reason it is such a high profile tyre is so that it is has a comparable overall diameter that of the 21" option, the same as the 22" rim option probably has 40 profile. I would not think L/R will change the diff ratios depending on whether a customer has specified 20" 21" or 22" rims they would compensate with a different profile tyre.
Col, thanks for the reply.
I wouldn't know if they changed ratios between the RRS1 and RRS2 but as I say I am running 21" rims from a RRS2 on a RRS1 and the speedo difference is with the 21" rim's at 30mph on the speedo the car is actually doing 31/32 mph. and at 70mph it is between 74/75mph. as the 275/45 x 21 and the 255/55 x 20 wheels have virtually the same overall diameter/ circumference I would have thought you would have a similar variation.
