Home > Faults & Fixes > Erratic revs & rattling noise |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 |
I know you've said you had all pulleys checked, but my thinking here is possible alternator bearing or internals. Reason I say that is normally the rev counter feed is taken off the alternator. If the alternator is rough and the tacho dance coincides with the noise, then it's a possible. |
Fri Nov 20 2015 6:05pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
Um, the engine speed is read from the crank speed sensor |
Fri Nov 20 2015 8:08pm |
Thats fair enough, I wasn't aware the RRS took the feed from there. A lot of vehicles use a feed from the alternator, certain models of LR included |
Sat Nov 21 2015 5:35pm |
quadcrosser Member Since: 15 Sep 2015 Location: herne Posts: 12 |
Is it like my noise ?
Tue Dec 01 2015 9:18pm |
Smithy 09 Member Since: 17 Nov 2015 Location: Kent Posts: 2 |
Hi there having same problem was thinking it was the talk converter |
Wed Feb 24 2016 10:13pm |
So I sent the turbo for a full rebuild.
Wed Feb 24 2016 11:21pm |
Murphyslaw Member Since: 10 Jul 2015 Location: Westmeath Posts: 6 |
Hi. No, the noise we are experiencing is that low, u wud struggle to record it.
Sun Mar 06 2016 10:16am |
