Home > Technical > Steering wheel wobble
Tomrogers
Hi I'm hoping someone might be able to shed some light on this issue at 50moh onwards I get a wobble through the steering wheel. I've done a search and it seems it could be a number of things from bottom arms bushes, tie rod ends, steering rack, wheel balance I obviously don't want to start going down the route of chucking parts at it unless I'm sure it's gonna fix it as it all soon adds up!
So here's the symptoms:
22inch alloys
Wobble above 50mph
Wobble continues if your cornering (only above 50mph)
Some roads won't do it at all and it'll be perfectly smooth then on another road it shakes you to bits!
Does it both on the power and coasting
So far I've had the wheels balanced and they are all ok, I've swapped front to rear and still the same. the tyre place said the tyres are 'ditch finders' and they said there cheap chienese tyres and said a new set of front tyres would cure it. The previous owner put these brand new crappy tyres on it 1 week before I've bought it so they've only covered 2000 miles. So I don't want to go replacing tyres unless I'm 90% sure it's gonna solve the problem while I know they could be the issue the tyre place is after all in the business of selling tyres so they are of course going to say they are the issue
Post #466379 Thu Jul 02 2015 11:08pm
Is it really on 24in rims? Shocked
Cheap tyres may well be the cause - even if not, cheap tyres on an expensive and very heavy 4x4 is just stupid. Put some half decent rubber on it before you find out how badly cheap tyres perform when it matters.
What year / version RRS is it? The early non-S/C versions came on small rims and didn't have the damped steering rack that was fitted to those that left the factory with 20in rims as standard. The rack became standard fit a few years in to the RRS's life. 2012 SDV6 - it's missing a couple of cylinders
Post #466383 Thu Jul 02 2015 11:54pm
Dan Stevens
Australia 2006 Range Rover Sport TDV6 SE Zermatt Silver
I'm running 22" rims and i had exactly the same issue.
Mine was cheap Chinese tyres that weren't round or correctly load rated for the vehicle.
Put a full set of new ones on and its perfect.
Post #466386 Fri Jul 03 2015 4:49am
Tomrogers
Sorry that was a typo the wheels are 22inch!! I've edited the original post now
It's a 2006 tdv6, is there any easy way to destiguish a damper rack from non?
The tyres are 'Durun' F-one , surprisingly they have a website! http://www.duruntyre.co.uk/english/car.htm
Post #466388 Fri Jul 03 2015 5:53am
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Tom,
It helps if you fill in your profile more fully including the vehicle profile.
Helps the helper.
Regards
Barry Very Happy 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #466403 Fri Jul 03 2015 9:24am
Tomrogers
Quick update for anyone who maybe having same problem, I had a new set of tyres on front which has made it much better but still a slight wobble but I've found some play in the drivers side front wheel bearing so I will change that tomorrow and see if it cures it
Post #466627 Sun Jul 05 2015 8:25pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
i had the same problem and changed my bottom arm bushes to poly ,wobble gone Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #466629 Sun Jul 05 2015 8:47pm
Tomrogers
Changed wheel bearing and it's sorted it !
Post #466791 Tue Jul 07 2015 10:50am
Tomrogers
I thought it was sorted but there must be another issue somewhere. It is now intermittent sometimes it all ok then all of a sudden it shakes worse than ever! Got mot tomorrow so hopefully they will pick up on any wear in bushes/bearings etc
Post #467386 Mon Jul 13 2015 11:49am
gazzc
tried everything on mine only thing that cured it was poly bushes Whistle silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #467409 Mon Jul 13 2015 6:15pm
Tomrogers
How's the ride on yours? I've read going to poly bushes can make it pretty harsh and I already thought it was harsh as it is running 22's !
Post #467416 Mon Jul 13 2015 7:29pm
gazzc
i put poly bushes on 2 of my sports and found the steering and ride much sharper and defined a big improvement and also stopped the dreaded 22 inch wheel wobble,although i don't own a sport now ...i got fed up of spending on them silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #467417 Mon Jul 13 2015 7:43pm
