![]() | Home > Technical > Steering wheel wobble |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Is it really on 24in rims? |
Dan Stevens Member Since: 19 Aug 2013 Location: Brisbane Posts: 47 ![]() ![]() ![]() |
I'm running 22" rims and i had exactly the same issue.
Tomrogers Member Since: 13 Jan 2015 Location: Mk Posts: 18 ![]() |
Sorry that was a typo the wheels are 22inch!! I've edited the original post now
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Tom,
Quick update for anyone who maybe having same problem, I had a new set of tyres on front which has made it much better but still a slight wobble but I've found some play in the drivers side front wheel bearing so I will change that tomorrow and see if it cures it |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
i had the same problem and changed my bottom arm bushes to poly ,wobble gone |
Changed wheel bearing and it's sorted it ! |
I thought it was sorted but there must be another issue somewhere. It is now intermittent sometimes it all ok then all of a sudden it shakes worse than ever! Got mot tomorrow so hopefully they will pick up on any wear in bushes/bearings etc |
tried everything on mine only thing that cured it was poly bushes |
How's the ride on yours? I've read going to poly bushes can make it pretty harsh and I already thought it was harsh as it is running 22's ! |
i put poly bushes on 2 of my sports and found the steering and ride much sharper and defined a big improvement and also stopped the dreaded 22 inch wheel wobble,although i don't own a sport now ...i got fed up of spending on them silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
