Home > General > Baby seat advice required |
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 |
I used a maxi cosi with a base that clipped in and out and was great can't remember the model but you need to go and try a few most places test fit them for you to get the correct fitting one for your car. As for a seat protector I used to use a soft baby blanket but was told not to so now I don't use anything. But the best buy is the new toddler seat I have which is also maxi cosi and it turns sideways to help get them out and that I would recommend to anyone as it had been a real back saver now my little one is a bit older and heavier. Here she is modelling the new seat which is a belt in and ratchet style
Thu May 14 2015 10:47am |
Somerset Bumpkin Member Since: 12 Dec 2012 Location: Swindon Posts: 74 |
We used a maxi-cosi with an Iso-Fix, family fix base unit. It's brilliant and now we.ve dusted it off to use again for our second.
Thu May 14 2015 2:33pm |
pintof80 Member Since: 23 Oct 2011 Location: Edinburgh Posts: 13 |
Thanks both!
Thu May 14 2015 6:05pm |
mr_spaceuk Member Since: 26 Apr 2015 Location: Berkshire Posts: 40 |
We have a Maxi-Cosi 2 way fix base with a pebble carrier.
Thu May 14 2015 7:05pm |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 |
We have the Maxi Cosi and family fix base. Definitely recommend getting the base, makes clicking in and out so much easier. It's a right paining belting the seat in to my L200! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Fri May 15 2015 10:51am |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 |
Like many others, we had the Maxi Cosi with Family Fix base, then followed up with replacing the Pebble with the Pearl.. worked a treat.
Fri May 15 2015 3:57pm |
We never bothered with a pearl. We went for one which swivelled which makes it so easy getting in and out when they start chunking up. Only downside to the swivel ones though was there was no isofix ones which was weird. I guess they were holding back the tech for next years new model... |
Fri May 15 2015 6:48pm |
Thanks all - so it's looks like a Pebble or Cabriofix seat with a FamilyFix base is the best option, and then move on to a Pearl later on.
Mon May 18 2015 5:30pm |
