Home > General > Baby seat advice required
pintof80
United Kingdom 2012 Range Rover Sport SDV6 HSE Baltic Blue
Morning all,
Our fist baby is due in just a few weeks, and so I need your advice on the best baby seat for the RRS.
Am I correct in thinking that an Isofix base and infant carrier is the best option (as opposed to a fixed seat)?
Any advice on which brand to go for? Maxi Cosi seems popular....
And what about seat protectors - any suggestions?
All and any advice welcome!
Thanks! 2012 RRS SDV6 HSE
Gone: 2006 RRS S/C
Post #461908 Thu May 14 2015 10:33am
Si-W85
I used a maxi cosi with a base that clipped in and out and was great can't remember the model but you need to go and try a few most places test fit them for you to get the correct fitting one for your car. As for a seat protector I used to use a soft baby blanket but was told not to so now I don't use anything. But the best buy is the new toddler seat I have which is also maxi cosi and it turns sideways to help get them out and that I would recommend to anyone as it had been a real back saver now my little one is a bit older and heavier. Here she is modelling the new seat which is a belt in and ratchet style Wink
Post #461912 Thu May 14 2015 11:47am
Somerset Bumpkin
2010 Range Rover Sport 3.0 TDV6 HSE Java Black
We used a maxi-cosi with an Iso-Fix, family fix base unit. It's brilliant and now we.ve dusted it off to use again for our second.
The base clips in nice and securely and the maxi-cosi just sits on top and you get a couple of beeps and a green light to tell you that it's secure.
Post #461933 Thu May 14 2015 3:33pm
pintof80
Thanks both!
Argos have a deal on the Maxi Cosi CabrioFix seat and base at the moment, so that might be a good option. 2012 RRS SDV6 HSE
Gone: 2006 RRS S/C
Post #461959 Thu May 14 2015 7:05pm
mr_spaceuk
We have a Maxi-Cosi 2 way fix base with a pebble carrier.
I believe that a new law is coming in to effect shortly that the kid has to be in a rear facing car seat.
http://www.parentdish.co.uk/baby/child-car...-products/
Post #461963 Thu May 14 2015 8:05pm
RossM
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
We have the Maxi Cosi and family fix base. Definitely recommend getting the base, makes clicking in and out so much easier. It's a right paining belting the seat in to my L200! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #461991 Fri May 15 2015 11:51am
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Like many others, we had the Maxi Cosi with Family Fix base, then followed up with replacing the Pebble with the Pearl.. worked a treat.
Cheers..
Ian
Post #462015 Fri May 15 2015 4:57pm
Somerset Bumpkin
We never bothered with a pearl. We went for one which swivelled which makes it so easy getting in and out when they start chunking up. Only downside to the swivel ones though was there was no isofix ones which was weird. I guess they were holding back the tech for next years new model...
Post #462023 Fri May 15 2015 7:48pm
pintof80
Thanks all - so it's looks like a Pebble or Cabriofix seat with a FamilyFix base is the best option, and then move on to a Pearl later on.
Now just to decide between Pebble & Cabriofix... 2012 RRS SDV6 HSE
Gone: 2006 RRS S/C
Post #462225 Mon May 18 2015 6:30pm
