Home > Maintenance & Modifications > Switched feed in overhead console
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Going to fit a Roadhawk dash cam. Am I right in saying there is a green & white wire in the overhead console a switched live feed, which will power the camera, and switch off when the car is parked.
Thanks MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #458471 Tue Apr 07 2015 10:38am
Paddi
Yes. Great description here:
http://www.rangerovers.net/forum/9-range-r...ector.html 2008 MY Java Black TDV8 HSE
Post #458474 Tue Apr 07 2015 11:26am
hse-lee
mmm interesting would this type of hardwiring work for a dash cam that i plan on installing soon, or would the cigarette type lead thats mostly supplied with these kits not be suitable
Post #458475 Tue Apr 07 2015 11:43am
Paddi
Yes it is great for dash cams: very quick and clean. The cigarette lighter lead usually has the transformer to drop the voltage down to what the camera needs incorporated into the plug part. To hardwire you need a err.. hardwire kit which the camera supplier will sell you. If you know the voltage and current required a suitable transformer can be sourced directly from a chinese supplier via eBay for next to nothing (mine was less than £2). The transformer can be tucked away in the overhead console and secured with double sided tape.
The only thing to note is the method described is for switched power. For constant power you would need to find a permanently live wire in the console if there is one. 2008 MY Java Black TDV8 HSE
Post #458480 Tue Apr 07 2015 1:08pm
Garage Door Medic
I did purchase a hard wired kit, it came also with a cigarette plug thingy, but don't want to see wires. I have read all the post, but was just checking to see if there was any further info. I just want it to turn on & off when I get in & out. I've read bout the Black view ones which record when it's left but mine only moves at weekend and a couple of nights a week. Thanks for the info Thumbs Up MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #458494 Tue Apr 07 2015 3:38pm
jimbg
Just cut off the cigar lighter adapter and then wire it in? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #458495 Tue Apr 07 2015 3:44pm
Paddi
Yes if you wire it as per the linked guide the camera switches itself on when you u ock the car and switches off when you lock up.
To answer Jimbg's question: the cigarette lighter plug in the systems I've seen incorporates the step down transformer from 12v to 5v so if you cut it off and wire in like that the camera would presumably be fried.
Maybe some cameras use 12v but you would need to check the specification sheet. ? 2008 MY Java Black TDV8 HSE
Post #458498 Tue Apr 07 2015 4:13pm
Garage Door Medic
My hard wired kit, comes with a inline fuse and a little black box, before it goes to the camera, so I think you are correct Paddi MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #458499 Tue Apr 07 2015 4:18pm
jimbg
Whoops!! I did not appreciate that it had a step down transformer, I assumed it was a straight 12 volt plug. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #458514 Tue Apr 07 2015 5:27pm
Garage Door Medic
Thanks for all the comments, fitted my dash camera yesterday, 15 mins done & dusted. Thumbs Up Thumbs Up MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #458730 Thu Apr 09 2015 7:57pm
Paddi
Thumbs Up sounds like a result. All you need to do now is find your way around the million different settings on the camera and playback software? 2008 MY Java Black TDV8 HSE
Post #458733 Thu Apr 09 2015 8:30pm
shakeapaw
can we have pictures please Smile 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #458872 Sat Apr 11 2015 9:00pm
zaphod
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
I've did something very similar a few weeks ago - hard wired in a Dashcam and a Cheetah C150 speed camera detector. The Cheetah was 12v so I could just cut off the cigarette lighter part but the Dashcam was 5v. Instead of paying for a dedicated hardwire kit I just got a 12v-5v step-down transformer of eBay for a couple of quid and jobs a good'n.
You WILL definitely blow the circuits in the dashcam if it's 5v and you wire it up directly to the 12v - I'm speaking from experience Laughing
Few pictures:
Step-down transformer
Wiring
Both wired up and working
Post #458901 Sun Apr 12 2015 7:21am
Garage Door Medic
I can't see my dash cam, when sat in drivers seat, so hopefully when it goes for servicing or cleaning, they won't see it either when they take it for a drive !!!!
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #458955 Sun Apr 12 2015 4:16pm
Garage Door Medic
Why has my photos loaded sideways ??? MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #458956 Sun Apr 12 2015 4:17pm
