![]() | Home > Maintenance & Modifications > Switched feed in overhead console |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
Assuming you have uploaded your pics to the forum gallery you can fix the images by going to the "Gallery" link (top right - black menu strip) then select "My Gallery" from the orange menu strip. Now click on the image you want to rotate and then select the "Crop and Rotate" button underneath it on the left. There will be a drop down menu in the top-left corner where you can rotate left and right or even flip upside down. Select preview to check it looks the way you want and the click save. |
hario69 Member Since: 06 Jan 2009 Location: Teesside Posts: 68 ![]() ![]() |
Hello
