Home > General > Flat Battery.... Charging at 15.1v...? Regulator Fault...? |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Yep, as per my post on the other thread: http://www.rrsport.co.uk/forum/post458690.html#458690 Visiting from DISCO3.CO.UK
Thu Apr 09 2015 5:15pm |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Noticed the last few days that I'm occasionally getting the "low battery" symbol popping up on the stereo. This only seems to be when I've been using my iPhone and Aux-in.
Tue Apr 21 2015 1:18pm |
I would certainly be keeping an eye on the alternator and checking for a battery drain. Visiting from DISCO3.CO.UK
Tue Apr 21 2015 4:20pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
Low power on the radio when the engine is running points to a low battery. You do need to check the battery when cold (first thing in the morning or at least 4 hours after last run) and also the alternator output (voltage whilst engine running basically). 2012 SDV6 - it's missing a couple of cylinders
Tue Apr 21 2015 6:20pm |
My worry is that the battery is brand new, and I've had the message.
Tue Apr 21 2015 6:29pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
I will wade in here. I don't think you have an issue
Sun Apr 26 2015 4:41pm |
Cheers Mike, appreciate that post!
Sun Apr 26 2015 4:49pm |
