Home > Maintenance & Modifications > How often are you topping up your coolant?
Mahrenholz
2010 Range Rover Sport TDV8 HSE Santorini Black
Hi
I have a MY2010 59 plate TDV8. I'm getting the dashboard message to top up the coolant approximately every 3 weeks on moderate use of the car. When I top it up the level is below where it should be ie, it's not a faulty error message
I took it in to an Indy who couldn't find a problem
Any ideas? Is this normal for a RRS?
Thanks
Karl
Post #457525 Sun Mar 29 2015 4:56pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
never had to top up on any of mine and i have had every engine,get a pressure test done Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #457533 Sun Mar 29 2015 6:26pm
riverblanche
Hi
Had a 57 plate D3 for over a year and 8k miles only had to top it up once from low to max, ISTR some blocks are more porous than others due to the magnesium content (or something like that!)
My RRS has never used a drop 1 year on and 6k
As Gazzc says have it checked, any antifreeze stains on hoses anywhere ?
Post #457548 Sun Mar 29 2015 8:06pm
My 2008MY TDV8 needed a new thermostat housing (the one in the V of the engine as it had cracked). It was losing a little coolant over time.
You probably need a pressure test to try to isolate the location of any leak. 2012 SDV6 - it's missing a couple of cylinders
Post #457560 Sun Mar 29 2015 9:31pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Perhaps a sinking sensor float in the top-up bottle.
A common issue based on other posts on here.
Does it actually require additional fluid or is it just the indicator?
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #457572 Sun Mar 29 2015 11:41pm
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
do the bottle and sensor (Coolant bottle LR020367 £41.35)
I have the same, though it's not a dicky sensor but rather a (very) slow leak. Will be pressure testing this week to find the source Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #457586 Mon Mar 30 2015 9:23am
Mahrenholz
Regards
Barry
It does actually need the additional fluid
Post #457699 Mon Mar 30 2015 7:13pm
drdelrrs
It shouldn't use an coolant.
Pressure check needed to find leak. Hopefully its not a cylinder head gasket causing pressure to blow coolant out.
Post #457831 Tue Mar 31 2015 9:29pm
The EGR coolers can leak I believe. Won't be obvious externally if it's weeping in to the exhaust. 2012 SDV6 - it's missing a couple of cylinders
Post #457837 Tue Mar 31 2015 9:45pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Common fault, dodgy sensor, mine comes on every f few months the disappears, sensor at the bottom of the reservoir renounced for false indication
Post #458540 Wed Apr 08 2015 1:00am
gogsy1956
i have the exact same model and year ,,,, never topped it up since purchase ( nearly 2 years ) 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #458543 Wed Apr 08 2015 5:28am
