![]() | Home > Maintenance & Modifications > How often are you topping up your coolant? |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
never had to top up on any of mine and i have had every engine,get a pressure test done |
Hi
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
My 2008MY TDV8 needed a new thermostat housing (the one in the V of the engine as it had cracked). It was losing a little coolant over time.
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Perhaps a sinking sensor float in the top-up bottle.
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 ![]() ![]() ![]() |
do the bottle and sensor (Coolant bottle LR020367 £41.35)
Mahrenholz Member Since: 16 Feb 2014 Location: UK Posts: 15 ![]() ![]() |
It does actually need the additional fluid |
It shouldn't use an coolant.
The EGR coolers can leak I believe. Won't be obvious externally if it's weeping in to the exhaust. 2012 SDV6 - it's missing a couple of cylinders
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Common fault, dodgy sensor, mine comes on every f few months the disappears, sensor at the bottom of the reservoir renounced for false indication |
i have the exact same model and year ,,,, never topped it up since purchase ( nearly 2 years ) 2010 RRS, TDV8
