Home > Maintenance & Modifications > How often are you topping up your coolant? |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
never had to top up on any of mine and i have had every engine,get a pressure test done silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Sun Mar 29 2015 5:26pm |
Hi
Sun Mar 29 2015 7:06pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
My 2008MY TDV8 needed a new thermostat housing (the one in the V of the engine as it had cracked). It was losing a little coolant over time.
Sun Mar 29 2015 8:31pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
Perhaps a sinking sensor float in the top-up bottle.
Sun Mar 29 2015 10:41pm |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
do the bottle and sensor (Coolant bottle LR020367 £41.35)
Mon Mar 30 2015 8:23am |
Mahrenholz Member Since: 16 Feb 2014 Location: UK Posts: 15 |
It does actually need the additional fluid |
Mon Mar 30 2015 6:13pm |
It shouldn't use an coolant.
Tue Mar 31 2015 8:29pm |
The EGR coolers can leak I believe. Won't be obvious externally if it's weeping in to the exhaust. 2012 SDV6 - it's missing a couple of cylinders
Tue Mar 31 2015 8:45pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Common fault, dodgy sensor, mine comes on every f few months the disappears, sensor at the bottom of the reservoir renounced for false indication |
Wed Apr 08 2015 12:00am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
i have the exact same model and year ,,,, never topped it up since purchase ( nearly 2 years ) 2010 RRS, TDV8
Wed Apr 08 2015 4:28am |
