Home > Faults & Fixes > Yellow engine warning light?? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
Not knowing what engine you have or how old it is makes it rather tricky to answer!
Sun Mar 08 2015 11:02am |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 160 |
its on 06 sc |
Sun Mar 08 2015 3:29pm |
Needs to have the fault codes read - that will tell you what it's not happy about. 2012 SDV6 - it's missing a couple of cylinders
Sun Mar 08 2015 4:34pm |
cheers,disconnected the battery,if comes on again ,think i'm gonna buy a fault code reader |
Sun Mar 08 2015 4:41pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
On a petrol, it's likely to be a lambda sensor, unless it's got LPG, then its a fuel trim issue |
Sun Mar 08 2015 6:45pm |
cheers,I'll probably start with changing that |
Sun Mar 08 2015 7:32pm |
There are 4 lambda sensors. Unless you have deep pockets, a diagnostic session is the way forward |
Sun Mar 08 2015 7:49pm |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 |
hi all ive got a 2007 rrs the engine simble light has come on (not flashed) andstays on ,what would this be as fault wise ?? have had the sport for neally 6 years and no engine (amber light) has ever come on!!! any help please
Tue Apr 14 2015 3:31pm |
On a TDV6, it will be EGR valve/s.
Tue Apr 14 2015 4:10pm |
