Home > Faults & Fixes > Yellow engine warning light??
daxmatt
The engine warning light has come on,not flashing
looked in the handbook,says emmisions warning light.
What does that mean,could it be the lamder sensor or something like that ?
Cheers for any help
Matt
Post #455086 Sun Mar 08 2015 9:18am
Not knowing what engine you have or how old it is makes it rather tricky to answer!
Best guess would be EGR valve failure if it's a diesel. 2012 SDV6 - it's missing a couple of cylinders
Post #455103 Sun Mar 08 2015 11:02am
daxmatt
its on 06 sc
Post #455124 Sun Mar 08 2015 3:29pm
Needs to have the fault codes read - that will tell you what it's not happy about. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #455132 Sun Mar 08 2015 4:34pm
daxmatt
cheers,disconnected the battery,if comes on again ,think i'm gonna buy a fault code reader
Post #455134 Sun Mar 08 2015 4:41pm
Disco_Mikey
On a petrol, it's likely to be a lambda sensor, unless it's got LPG, then its a fuel trim issue Thumbs Up
Post #455159 Sun Mar 08 2015 6:45pm
daxmatt
cheers,I'll probably start with changing that
Post #455167 Sun Mar 08 2015 7:32pm
Disco_Mikey
There are 4 lambda sensors. Unless you have deep pockets, a diagnostic session is the way forward Thumbs Up
Post #455171 Sun Mar 08 2015 7:49pm
SONYBOY
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
engine light in dash
hi all ive got a 2007 rrs the engine simble light has come on (not flashed) andstays on ,what would this be as fault wise ?? have had the sport for neally 6 years and no engine (amber light) has ever come on!!! any help please
regards 2007 COOLRRS
Post #459162 Tue Apr 14 2015 3:31pm
Disco_Mikey
On a TDV6, it will be EGR valve/s.
Either replace them, or blank them and have them mapped out Thumbs Up
Post #459165 Tue Apr 14 2015 4:10pm
