Home > Faults & Fixes > car shakes at 70mph- help |
Goreskin65 Member Since: 07 Jan 2015 Location: Portsmouth Posts: 32 |
Parking brake shoes worn, it's what I had the vibration came on at 70 so I reduced to 50 then it disappeared and was told on here it's the EPB |
Sun Feb 08 2015 10:46pm |
king9750 Member Since: 31 Jan 2015 Location: Maidstone Posts: 7 |
Thanks. Will the parking brake do this? Other times I drive at 75 /80 mph, no issue. Its only a few times at 70 mph it has ocurred. Parking brake operates fine with no issues though? |
Sun Feb 08 2015 10:51pm |
parkig brake or any of the calipers sticking. Bodsys Brake Bible
Sun Feb 08 2015 11:05pm |
Honestly chap it was bodsy who told me about the fault |
Mon Feb 09 2015 8:50am |
I believe you.lol. But the independent i'm using aint having it. I'm taking it round there next monday. |
Mon Feb 09 2015 11:29am |
it goes after you drop the rev's....? probably not the brakes then, could be EGR valve fluttering, or possibly cross over pipe leaking causing some spurious issue? Bodsys Brake Bible
Mon Feb 09 2015 12:38pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Check the center prop mount, it might have perished, or the bearing gone...
Mon Feb 09 2015 1:03pm |
kevtydd Member Since: 28 Jan 2015 Location: llanrwst Posts: 5 |
I had something similar lately on my 58 rrs tdv8 hst .About 10 miles after leaving a hand car wash place the whole vehicle was vibrating at about 60 ! Pulled over and had a quick look incase of loose wheels , but nothing, so carried on home and nothing since ! Don't know whether water from jetwash they used got into something under arches ? oOk now , fingers crossed ! |
Thu Feb 12 2015 7:20pm |
You might want to check the harmonic dampers (two weights, either side behind the rear wheels) swing freely and aren't contacting the bodywork. |
Fri Feb 13 2015 4:22pm |
Well took it to the garage, found an EGR fault which he is blanking out. He states its a gearbox issue and possible need a gearbox change. Don't know if I believe him as it drives perfect round town and on country roads at 50 / 60 mph but will try a gearbox flush and see what happens. Hopefully the EGR blanking may help also. It's a waiting game. |
Mon Feb 16 2015 8:39pm |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
Hope you got it fixed. I had exactly the same issue, and mine was water in the tyres. |
Mon Jun 29 2015 6:31am |
Well,
Mon Jun 29 2015 7:36am |
