Home > Faults & Fixes > car shakes at 70mph- help
king9750
England 2006 Range Rover Sport TDV6 Autobiography Stornoway Grey
Hi guys,
Need some help, recently purchased a RRS 2.7TDV6 and now and then the car begins to shake and rattle at 70mph (2000 rpm) which goes through the whole vehicle. It goes after I drop the revs and re apply. I never experience this around town and its only intermittent on the motorway. Im taking it to the local garage to check but no faults come up on the dash. It has happened twice this week. Any ideas??
Post #451838 Sun Feb 08 2015 10:35pm
Goreskin65
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
Parking brake shoes worn, it's what I had the vibration came on at 70 so I reduced to 50 then it disappeared and was told on here it's the EPB
Post #451841 Sun Feb 08 2015 10:46pm
king9750
Thanks. Will the parking brake do this? Other times I drive at 75 /80 mph, no issue. Its only a few times at 70 mph it has ocurred. Parking brake operates fine with no issues though?
Post #451842 Sun Feb 08 2015 10:51pm
Bodsy
Site Sponsor
parkig brake or any of the calipers sticking. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #451844 Sun Feb 08 2015 11:05pm
Goreskin65
Honestly chap it was bodsy who told me about the fault Thumbs Up Thumbs Up
Post #451851 Mon Feb 09 2015 8:50am
king9750
I believe you.lol. But the independent i'm using aint having it. I'm taking it round there next monday.
Post #451864 Mon Feb 09 2015 11:29am
Bodsy
Site Sponsor
it goes after you drop the rev's....? probably not the brakes then, could be EGR valve fluttering, or possibly cross over pipe leaking causing some spurious issue? Bodsys Brake Bible
See it HERE
Post #451866 Mon Feb 09 2015 12:38pm
flack
Check the center prop mount, it might have perished, or the bearing gone...
Flack Thumbs Up
Post #451870 Mon Feb 09 2015 1:03pm
kevtydd
Wales 2008 Range Rover Sport TDV8 HST Java Black
I had something similar lately on my 58 rrs tdv8 hst .About 10 miles after leaving a hand car wash place the whole vehicle was vibrating at about 60 ! Pulled over and had a quick look incase of loose wheels , but nothing, so carried on home and nothing since ! Don't know whether water from jetwash they used got into something under arches ? oOk now , fingers crossed !
Post #452378 Thu Feb 12 2015 7:20pm
drdelrrs
You might want to check the harmonic dampers (two weights, either side behind the rear wheels) swing freely and aren't contacting the bodywork.
Post #452440 Fri Feb 13 2015 4:22pm
king9750
Well took it to the garage, found an EGR fault which he is blanking out. He states its a gearbox issue and possible need a gearbox change. Don't know if I believe him as it drives perfect round town and on country roads at 50 / 60 mph but will try a gearbox flush and see what happens. Hopefully the EGR blanking may help also. It's a waiting game.
Post #452765 Mon Feb 16 2015 8:39pm
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
Hope you got it fixed. I had exactly the same issue, and mine was water in the tyres.
Post #465987 Mon Jun 29 2015 6:31am
king9750
Well,
Had the EGR valves blanked about 3 to 4 months ago and no more shaking at that speed. Gearbox is ok and drives fine. Will need to do some wheel balancing and tracking as I've just downsized from 22s to standard 20s.
Post #465990 Mon Jun 29 2015 7:36am
