![]() | Home > Faults & Fixes > car shakes at 70mph- help |
Goreskin65 Member Since: 07 Jan 2015 Location: Portsmouth Posts: 32 ![]() ![]() ![]() |
Parking brake shoes worn, it's what I had the vibration came on at 70 so I reduced to 50 then it disappeared and was told on here it's the EPB |
king9750 Member Since: 31 Jan 2015 Location: Maidstone Posts: 7 ![]() ![]() ![]() |
Thanks. Will the parking brake do this? Other times I drive at 75 /80 mph, no issue. Its only a few times at 70 mph it has ocurred. Parking brake operates fine with no issues though? |
parkig brake or any of the calipers sticking. |
Honestly chap it was bodsy who told me about the fault |
I believe you.lol. But the independent i'm using aint having it. I'm taking it round there next monday. |
it goes after you drop the rev's....? probably not the brakes then, could be EGR valve fluttering, or possibly cross over pipe leaking causing some spurious issue? Bodsys Brake Bible
Check the center prop mount, it might have perished, or the bearing gone...
kevtydd Member Since: 28 Jan 2015 Location: llanrwst Posts: 5 ![]() ![]() ![]() |
I had something similar lately on my 58 rrs tdv8 hst .About 10 miles after leaving a hand car wash place the whole vehicle was vibrating at about 60 ! Pulled over and had a quick look incase of loose wheels , but nothing, so carried on home and nothing since ! Don't know whether water from jetwash they used got into something under arches ? oOk now , fingers crossed ! |
You might want to check the harmonic dampers (two weights, either side behind the rear wheels) swing freely and aren't contacting the bodywork. |
Well took it to the garage, found an EGR fault which he is blanking out. He states its a gearbox issue and possible need a gearbox change. Don't know if I believe him as it drives perfect round town and on country roads at 50 / 60 mph but will try a gearbox flush and see what happens. Hopefully the EGR blanking may help also. It's a waiting game. |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
Hope you got it fixed. I had exactly the same issue, and mine was water in the tyres. |
Well,
