Home > Faults & Fixes > Suspension fault C1A20-64 - how to fix
Page 2 of 4 <1234>
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
pm sent
Post #466074 Mon Jun 29 2015 9:49pm
Miller
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
Miller wrote:
Suspension failure light came on today on 2006 tdv6 70,000 only had it a week Big Cry but once turned off and on agin it's been fine !! Is this Likely to be the fault ? , sorry to be vague but only just happened and I've only just got rid of a BMW X5 that was rippled with faults witch put me through 8 weeks of hell !
my light has never come back on (touch wood) but the suspension has started to lower slightly over night Sad would a new cap solve this or is it another fault ?
cheers
Post #466098 Tue Jun 30 2015 9:03am
wings21660
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Mine was like yours Mick so I printed off the way Ignas described it. Showed it to the mechanic then ordered the parts job done Thumbs Up
Post #466346 Thu Jul 02 2015 6:06pm
fordyboi
hi mate just done the soapy solution spray test and its just as you say leaking from in between the hoses .
>>>>>I need to order one of these how do I do this ?<<<<<
Post #471615 Tue Sep 01 2015 3:06pm
wings21660
Hi pal you need to look up a guy called gruodiz from Lithuania in faults and fixes he'll sell you the kit
Post #471633 Tue Sep 01 2015 7:10pm
Gilly1
Compressor cover
hi gruodiz, I've pmd you but thought I'd drop a reply on here also, do you still supply the compressor covers as I would like to purchase 1 from you, regards lee.
Post #472231 Sun Sep 06 2015 7:53pm
fordyboi
Just fitted a similar part to this today i managed to find a part on ebay the same as the original but metal .this is an awesome fix and solved it, also only took 30mins if you struggle to source a part they are on ebay gilly. Awesome write up though cudnt have fixed so cheap without this
Post #472235 Sun Sep 06 2015 8:35pm
Gilly1
Cool, thanks fordyboi, have you got link or item number for the part, if I get the same one I no it's correct as yours is now fitted, 😀 not got a issue as yet but thought I'd be prepared as sounds like it's a part needed sooner or later, not had the sport that long but couple little issues, 1) rear wiper not wiping but motor working ( took motor apart and found warn plastic cog ordered one from eBay hopefully sort it) 2) 2 pdc sensors on rear 1 on front (replaced job done) 3) now got temperamental osf door latch ( next job fitting that thanks to (I think Ian) who posted a good how 2) thanks again for reply. Thumbs Up
Post #472245 Sun Sep 06 2015 8:53pm
fordyboi
Hi bud yh the Item number eBay Item No. 171694006022
Post #472248 Sun Sep 06 2015 9:19pm
jammin
England 2007 Range Rover Sport TDV6 HSE Arctic Frost
superb nice upgrade will shout you if i ever need it sorting,,,,
Post #472249 Sun Sep 06 2015 9:30pm
Gilly1
Awesome thanks mate, sorry to be pain but what's the extra hole for, the factory 1 has got 6 torx holes but there is 7 on eBay Mr. Green Apologies if I'm being blond. Very Happy I'm thinking that's a slot for the pipe but thought I'd ask.
Post #472260 Sun Sep 06 2015 10:12pm
fordyboi
Not actually sure what thats for bud but it doesnt effect anything so all good .
Post #472289 Mon Sep 07 2015 8:21am
Gilly1
Cool, got 1 ordered thought might as well do it as probably does leak slightly but if not its done anyway. Thumbs Up
Post #472410 Tue Sep 08 2015 4:42pm
Imy
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
on my mechanic's machine it just reads c1a20.....will the cover fix the issue with the suspension fault
Any help would be appreciated
Post #479173 Mon Nov 09 2015 12:07am
lionthecatt
England 2008 Range Rover Sport TDV8 HST Zambezi Silver
End Cap
Hi are you still supplying this excellent piece of kit. I have a 08 model RR Sport.
Post #485894 Wed Jan 27 2016 7:58pm
Page 2 of 4 <1234>
